Matthew_VA's Avatar
weather was decent enough to get a proper wash in.
TBD
Prior: '84 911 3.2 Carrera, '83 911SC Targa
IG: @heuersandcarreras
"I want to use it. That's what 911s are for." - Richard Hammond
Old 02-04-2022, 03:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9801 (permalink)
Lightbulb Drilled my nuts for spring locks
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 02-04-2022, 06:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9802 (permalink)
Arrow Modified Seat Rail Adaptors
Seats are now .25” lower, doesn’t seem like much but it feels better.
Before: The adaptor was on top which and seats are a bit high: also you can see on the front passenger seat I added a .5” spacer to tilt the seats back a bit.
After: The seat adaptor is now under the stock mount, the adaptor and seat rail sandwich the stock mount. I could of just used some nuts on the low side but this way is sturdier and make use of the captive nuts so they aren’t rattling around.
Old 02-04-2022, 06:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9803 (permalink)
Installed a toggle switch to the AEM gauge.
Replaced the Master Brake Cylinder and bled the brakes.
Old 02-05-2022, 06:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9804 (permalink)
Enginerd
TxGerman's Avatar
Solved my rear suspension "clunk" and went for a lovely drive. Once I got home, proceeded to change the oil and install my new sump plate cover. It was a good day.....
1982 Guards Red 911SC, 1994 Riviera Blue RoW 993, 2020 British Racing Green Macan GTS
Gone but not forgotten: 2017 GT Silver Turbo S, 2012 Guards Red 991.1 C2S, 2017 Carrera White Macan GTS
IG: @pcar911fan
Old 02-05-2022, 06:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9805 (permalink)
Pedro '84 Coupe's Avatar
Continued my A/C resurrection. Last weekend I replaced the evaporator and the thermostat switch. Also installed the upgraded relay and the inline fuse for the front condenser motor. Gonna run new hoses then install the new front and rear condensers today/this weekend. Taking it to the shop Tuesday for them to install the compressor then charge it. Hopefully I don't screw up anything.
Old evap was toast...
As was the old hose. Griffith's provided a nice replacement.
The area underneath the evaporator wasn't too bad. No rust or mice thank goodness
2000 Boxster S and 2016 Audi A6
Old 02-18-2022, 08:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9806 (permalink)
I put a new knob on my Wevo shifter.
This one is Wine stained oak and the lighter stuff is Balsa wood. It's bonded to Brass.
76 911S
Land Rover 110 Defender
Old 02-18-2022, 07:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9807 (permalink)
http://forums.pelicanparts.com/uploads26/20220121_1340061643224687.jpg
I have this coupler as well. However, the bushings are worn. Any idea if they’re still available?
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 02-19-2022, 07:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9808 (permalink)
Also, I guess I did get something done on the 930. Even though it wasn’t today. Close enough.
Old 02-19-2022, 07:29 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9809 (permalink)
49willard
I have the same messy task lubing and rebooting the half shafts to do this week. I had to replace one of the inner Loebro joints which are suffering a temporary supply problem (a Loebro issue). Unfortunately on my 86 Cab the outer joint is not readily inspectable/replaceable like on the earlier halfshafts.
Bill
1961 356B coupe-long gone!
1986 Grand Prix White Cabriolet
Old 02-20-2022, 04:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9810 (permalink)
49willard
Originally Posted by thetorch View Post
I recommend removing the grease that comes with those axles and using a quality one like Redline CV2. The black/grey grease that came in my new Lobros axles was far too thin and made a significant mess of my underbody, starter, heat exchangers, cables, etc. within days.
Hear me now believe me later.
I am at that point. Can you tell me where it was leaking from?
Bill
Old 02-20-2022, 05:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9811 (permalink)
Cory M's Avatar
Not my 911, but helped a friend with his "G-body cup" 911. Rasant Products built 4 liter engine, Motec system, and lots more. Ended the night with a few rips up the street. This thing is a beast..
Old 02-20-2022, 08:34 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9812 (permalink)
Got the old AC hoses out and installed the new ones. Had to cut the driver's side hose. What a pain. The passenger side hose was super easy. It goes to the shop Tuesday to charge the system.
Old 02-20-2022, 06:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9813 (permalink)
Eva
911SauCy's Avatar
Decided to go down the suspension slippery slope...
More to come
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 02-21-2022, 09:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9814 (permalink)
Enginerd
TxGerman's Avatar
Nice job, that's in my future as well....
IG: @pcar911fan
Old 02-21-2022, 10:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9815 (permalink)
Porsche Crest
Installed rear rebel racing bushings and adjustable spring plates.
Adjusted ride height and adjusted camber and toe.
Old 02-21-2022, 05:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9816 (permalink)
Matthew_VA's Avatar
Finally reinstalled my strut bar. It was not fun cutting into those very nice carbone mats but guess it was a necessary evil!
TBD
Old 02-23-2022, 06:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9817 (permalink)
Got the car back from the mechanic. AC install was a success and I didn't screw up anything haha. It's colder than a witch's you-know-what today so couldn't really test the AC although it did clear up the foggy windows almost instantly. Maybe I can try it out in March...
Old 02-23-2022, 09:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9818 (permalink)
wash, clay bar, orbital buff, carnauba wax, cover.
Last night, -5° F outside. I can run this for about 10 minutes an hour, keeps it toasty and not oxygen deprived.
Where do all these scratches and swirls come from?
I have not used an orbital. It takes hours for each section. I used wool pads. Totally a mirror finish. Everything in this picture that is not red is a reflection of things in the background.
It's kind of fun just to stare at it.
That's a wrap.
Ken
'69 911E
Old 02-23-2022, 01:39 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9819 (permalink)
Matthew_VA's Avatar
paint refresh on the front intake vent grille and trim.
it's the small little things...
TBD
Old 02-24-2022, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #9820 (permalink)
Tags
fuchs are ugly , stock sucks
