Burnin' Rubber
Koizumi's Avatar
What did you do to your 911 today?
Added outside ambient air temperature sensor and gauge since I am obsessed with correct temp readings. Super accurate!
Took me a while to get the probe in the right spot - to the left of the ride side fog light, tucked under the bumper lip so no direct sunlight to throw off readings.
Old 11-26-2025, 03:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11361 (permalink)
Kind of Blue
MrBonus's Avatar
My driver's seat developed an annoying creak and Silverlock's seat swap inspired me to fix it and get rid of my ugly metal mounting screws and replace them with black screws.
I also somehow FINALLY found an irritating 3000 - 4500 RPM rattle after YEARS of chasing it down. The rear grill mesh was rattling against the Clewett rain hats.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 11-27-2025, 06:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11362 (permalink)
Nice! Always the little things. Looks good.
Tell me about it. My rear parcel shelf developed a creak around 3500RPM (harmonics!) and so I’ve gone through and replaced all of the worn self-tappers that hold the 3/4 panels, trim and rear shelf down with fresh black oxide screws + finish washers to tighten it all up.
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings)
Dynamic Comp Ratio calc: https://dcr.questionable.services/ • Gearset & Ratio calc: https://ratio.questionable.services/
Old 11-27-2025, 07:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11363 (permalink)
Great ideas here , I'm chasing squeaks in my Targa , way to start somewhere !
Old 11-27-2025, 08:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11364 (permalink)
Haha, I finally found the clanging noise in my driver side door, the window regulator needs to be replaced and now
I think I am with the noise, that’s a pain in the rear to do, lol
87 Venetian Blue 3.4
Old 11-27-2025, 05:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11365 (permalink)
RDM RDM is offline
Coram Deo
RDM's Avatar
Tis the Season (especially with our forecast) to put the summer tires away. In my case, that included buying a new set of tires, Conti Extreme Contact Sport 2. Much more exciting than the regular Michelins that the W124s get...
I think I'm ready for spring.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio
Old 11-28-2025, 03:41 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11366 (permalink)
A930Rocket's Avatar
Replaced the receiver dryer, and I’ve got the vacuum pump on it now. It’s been holding a vacuum now for about 2 1/2 hours.
Started to replace the flywheel sensors and CHT sensor, but I ordered the wrong CHT sensor. I don’t want to pull the flywheel sensors through the sheet metal until I get the correct CHT sensor.
No driving the car now for a couple days until I get the new part
Old 11-28-2025, 04:06 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11367 (permalink)
I started to measure and drill for a through body sway bar.
76 911S
Land Rover 110 Defender
Old 11-29-2025, 01:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11368 (permalink)
A930Rocket's Avatar
^^^ Check your clearance between the gas tank and the sway bar. It can get close if off.
Old 11-29-2025, 04:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11369 (permalink)
Thanks,
I will. My greater concern is the clearance between the sway bar and the brake pipes. As its a Right hand Drive, the pipes cross from the left side of the car to the right. And in that space between the tank and the cabin wall.
76 911S
Old 11-29-2025, 04:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11370 (permalink)
Originally Posted by ben parrish View Post
I also ordered a small battery hold down ..........
I love the straps, looks much nicer than the thing I rigged up.
I trust battery acid isn't going to eat the nylon straps over time.
I just tossed out a pair of wok gloves yesterday, pretty sure it was the battery acid from last weeks work.
As for my car, checked the battery tender last week and did a little something to keep the weather out of my work area.
Old 11-29-2025, 05:57 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11371 (permalink)
Stella's Garage Shift Spring! Such a good move.
Old 11-29-2025, 06:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11372 (permalink)
Old 11-30-2025, 08:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11373 (permalink)
I had no idea how badly I needed a new airbox cover until now.
'83 911SC - Rubinrot Metallic
IG: @911.sc.83
Old 12-01-2025, 10:56 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11374 (permalink)
The Dude abides...
bigel's Avatar
@Jaymanbikes13 no words needed I suppose...
'03 Carrera 4S
Old 12-03-2025, 01:49 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11375 (permalink)
Happiest when Tinkering
gsmith660's Avatar
Just finished repairing the 2nd gear in this 996 6 speed to adapt it to my 3.2 short stroke turbo engine
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go!
76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3
76 Blazer also restored by me
Old 12-03-2025, 02:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11376 (permalink)
Oil change, new oil filter.
Then replace the rear brake pads.
Then, while the car was on the lift, I cleaned a lot of tar off of the bottom of the car along the rocker panels.
And I cleaned a lot of dead bugs off of the front valance - spoiler area under the bumper. It is great to sit in my roll around chair and clean at eye level
Old 12-10-2025, 02:59 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11377 (permalink)
I'm about to do Oil, brakes, etc... very jealous of the lift - I clean bugs out of the valence all the time - but I have to do it laying on the floor!!
1986 Carrera 3.2 Coupe in Grand Prix White
IG: @c.cal.porsche
Old 12-10-2025, 03:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11378 (permalink)
Yea, the valance was covered in bugs, as I too hate to lay on the ground to clean the car.
And I did use my 3D printed oil funnel.
With 20-50 oil on a cool day, I started pouring it in with the spout of the of the oil bottle on the bottom, it glugs several glugs, and then I just shove the bottle all the way in, and let go. 100% of the oil empties from the bottle. Right now, only for 3.2 Carreras with the factory air intake.
We are hoping to get one designed for a stock SC this weekend.
Old 12-10-2025, 07:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11379 (permalink)
It was time to get back on the Targa and install the Brey Kraus Targa harness bar. Hopefully less squeaks and rattles when we start driving again.
Old 12-14-2025, 07:59 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #11380 (permalink)
Tags
fuchs are ugly , stock sucks
