Over time and when funds allow, I will replace other parts as outlined in all the other posts above!
Johann 1986 911 Carrera [SOLD] 1980 911SC [SOLD] 2004 911 |
Johann,
I have seen very few 911's with a/c belt vibration so bad you could feel it in the cockpit; either with stock compressors or aftermarket. Have you tried simply leaving the car in neutral, flat ground, e brake on, a/c on, deck lid up and have a mate increase the rpms (or push the throttle plate) so you could observe it? |
UnRegistered User
I don't know if this was mentioned as there are large parts of this thread that I just skipped over
, but what is the condition of the pulleys for the a/c system? If the belt had been loose and slipping for a long period of time the "Vee" inside the pulley is worn down and the belt starts to suck into the centre of the pulley. This could cause some interesting vibration problems.Good to see that you have it worked out, Johann. You have had some very good advice from some of the contributors. Cheers!
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Belt Vibration
First - Where were all you guys, when I was building my AC System
Definitely some "lively" discussion going on in this thread....As for the belt vibration, this caught my attention, as I literally just posted on this same topic. I designed my own system with a rotary vane compressor, so I figured I was the only one with this problem, but it looks like others have seen this with the original York recips and the conventional Sanden and Denso swash plate compressors. What I found is that V- belts will resonate at certain RPM ranges. Sometimes it is severe, and you can feel it in the car, and other times you never notice, unless you are looking for it. Usually, this vibration can be mitigated by increasing or decreasing the belt tension, or by changing the mass of the belt (use a thicker or thinner one to raise or lower the frequency at which it vibrates). When that doesn't work, you have to use idler pulleys to effectively add stiffness to the system at strategic points. One will usually do the trick, but for my system, I found out that my belt actually had dual vibration modes (I had to use a strobe light to actually see this). The ultimate fix was to use 2 idle pulley's on the top side (slack side) of the belt. The bottom of the belt is under the highest tension, so perhaps that side does not go into resonance until above 8000 RPM or so. Needless to say, mine looks great up to 6000, and I'm not testing it any further. I posted pictures of my fix on DIY Air Conditioning for old Porsches. Keep up the good work, guys. Even the (sometimes hard to understand)jabs back and forth have good information to gleen for the rest of us
Therein might lie the answer. More pumping capacity would undoubtedly lead to higher pressures, sustainable high side pressures, more pressure = more HEAT = improvement of heat transfer efficiency for both condensors. |
Banned
Man, I hate it when the "problem" shifts around to make the "solution" correct. |
Damn and I just ordered my SPAL fans and Spray on Insulation. LOL
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Banned
Hell, next wwest will tell us that SPAL fans will actually cool the interior of the car wihout the rest of the AC system present. Hell, just take out the motor and run a SPAL fan on the decklid - the car *will* run much cooler!
Back many years ago automotive design engineers figured out that more HEAT TRANSFER capability could be attained using the exact same engine cooling radiator by increasing the temperature of the coolant. So now we have PRESSURIZED systems to prevent boiling at sea level atmospheric pressure. |
Banned
Maybe this wording, posted June 2010, will be of help as a aid to your understanding. Quote:
Banned
Banned
More hilarity from wwest. This time in the form of irony.
| Tags |
| air conditioner , rough idle |
