Puma's Avatar
This is a nice thread. Thanks for taking your time to illustrate your methods.
Any updates?
2001 986 S
Old 07-10-2017, 03:01 PM
Thanks. There should be some updates and at some point I'll get them up. There have been some gaps, especially when I was working out of town for several months last year, but hopefully I'll get the thread caught up n the not too distant future.
Tim
'69 911e (work in progress)
‘20 Honda Ridegeline
'22 Subaru BRZ
Restoring Jewel's 911e
Old 07-11-2017, 07:39 PM
Been awhile, but…
After a significant gap (both in working on the car and in posting, but mostly in posting) I finally am getting around to updating my restoration post. Though I went through a about a year’s worth where not much was done there’s been progress and I’m nearing the end of the rust repair part of the job so here’s the somewhat abbreviated update.
I left off on the post with what was going to be a small patch in the smugglers box that turned out to be on top of one of the suspension pickups, leading to a further investigation of a previous set of repairs (and some consternation about taking all that apart- http://forums.pelicanparts.com/paint-bodywork-detailing-forum/867602-should-stay-should-go.html) and replacement of the tank support and other pieces.
Tim
'22 Subaru BRZ
Old 02-07-2019, 07:35 PM
In preparation for the tank support replacement and demo the full floor pan got an undercoating striping generating a pretty good mess, but fortunately not finding any new surprises beyond the front pan and making a big mess.
Disassembly of the old repair did yield a number of additional surprises that fully justified the decision to pull it all apart- as well as some interesting earlier fabrication and repair techniques.
Tim
'22 Subaru BRZ
Old 02-07-2019, 07:46 PM
The little patch from inside the smuggler’s box turned into this
The driver’s side was even worse, and required a few more fab’d parts
and that led into more demo in prep for the trunk pan
Tim
'22 Subaru BRZ
Old 02-07-2019, 08:01 PM
Lots of drilling of spot welds, beating and grinding
Led to a big hole in the front
And a check fit check of the new panels
Tim
'22 Subaru BRZ
Old 02-07-2019, 08:11 PM
Since the rot extended beyond the flanges where the new part met up with inner fender area I ended up cutting out more than the new pieces replaced. Then there were a number of pieces needed to fill the gaps.
Tim
'22 Subaru BRZ
Old 02-09-2019, 03:43 PM
The ugliest one was the one near the pickup for the front swing arm mount, but there ended up being a number of little pieces to be able to get the shapes close and welded in.
But ultimately the pan was on and the bottom gaps filled.
Tim
'22 Subaru BRZ
Old 02-09-2019, 03:48 PM
The trunk interior also required a number of interfacing panel fabs
Tim
'22 Subaru BRZ
Old 02-09-2019, 03:57 PM
Completing the left side and leading to a similar, but less involved process on the right side
And with the installation of the reinforcement plates over the pickup points it’s ready for the installation of the top panel
Tim
'22 Subaru BRZ
Old 02-09-2019, 04:06 PM
AirBorne!
Bravo, great work
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed
Old 02-10-2019, 09:07 AM
bugstrider's Avatar
Restoring Jewel’s 911e (Another ’69 e Restoration)
Fantastic metalwork!!! I am bookmarking this since I need to make similar repairs. I am just curious about you lateral tank supports that you custom fabed. What was your motivation to fab vs picking up ones already formed, say from Restoration Design? Just curious on that.
Mine are also in bad shape along with many other bits. Since you are tackling many parts, what are you using to support your project? Cart, jig, rotisserie, etc? In post #84, it looks like the octagon design.
Cheers
-Palpatine (Robot Chicken)
1978 911SC Targa
Working Projects: 1968 912
Old 02-22-2019, 05:42 AM
Steve F's Avatar
Thumbs up
Looking Great!!
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 02-22-2019, 05:47 AM
Looks really good, I love the handywork!
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 02-22-2019, 09:11 AM
Cheers
Yeah, the support is an “octisserie”, built like the one I first saw in Fishcop’s thread. It worked really well, but I’d pay a little more attention to the height dimensions to try to get the CG closer to center of the loop. It was a little difficult rolling back to “right side up” the way I built it.
As to the lateral tanks supports- those pieces were from a few years ago (I’m way behind getting pictures up and just now trying to catchup). I’m not completely sure those pieces were available then, but I suspect it was a combination of not wanting to buy a big piece to cut out the little piece I needed, thinking it wouldn’t be too big a deal to do compared to some of the ones I’d earlier, and some of the other issues I’d had with various reproduction parts that all took extra “massaging” to get them to fit.
Tim
'22 Subaru BRZ
Old 02-24-2019, 12:48 PM
Well, ultimately I got behind in posting updates and then just completely gave up on the thread- though work did continue. What will follow is a “quick” update to bring us up to the present- largely to help me get the story organized as I head into the bodywork, paint and reassembly phase. I’m going to try to get the thread up to date and cover the last 5 years over the next few days.
Tim
'22 Subaru BRZ
Old 09-09-2021, 09:49 PM
Also the Z3 and Mini are long gone, but the signature edit apparently doesn't like the link to this post and wouldn't save.
Tim
'22 Subaru BRZ
Old 09-09-2021, 09:51 PM
After I got the floor pans in, I took on the left rear where it had been backed into something wrinkling the engine cover, the rear valance panel between the bumperettes and shoving the left rear bumper guard into the rear cross member. The rear tip of the quarter panel above the taillight was also pushed down.
I made a couple of abortive attempts to pull the cross member back out with weld-on studs, but that didn’t work at all. So, out came the damaged part of the rear cross member, and the fab process started.
Built a wooden form,
shaped a panel to fit,
And welded it in. That all looked pretty good, though it turned out ultimately it wasn’t good enough.
Tim
'22 Subaru BRZ
Old 09-09-2021, 09:58 PM
From there I went after the tip of the rear quarter above the tail light where it was pushed in. After getting it stripped it was clear it wasn’t just bent, but torn as well.
After much sketching, cardboard templating, all while using the right side, the turn signal housing and the (new, used straight) engine cover as guides, I got a cut plan and new piece laid out,
cut out,
fabricated.
fitted and welded in (though I apparently didn’t take any welding progress pictures.
Around here’s where I ran into trouble.
Tim
'22 Subaru BRZ
Old 09-09-2021, 10:08 PM
Just around there? Yeah sure man, the rest looked so easy!
1982 911SC
Old 09-10-2021, 06:56 AM
