YAZ: be prepared to provide your VIN to Jim Ellis Porsche when you call them.
Thanks, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
Boy Howdy!
I looks like my measurements pretty close then... eyeball and ruler. |
Wanted to circle back on this thread with an update.
Rx'd the needed pin (today) from Loren at Systems Consulting. He did this on his own accord at no expense to myself nor Yaz. Big thanks for the gesture, Loren,..as we owe you one (favor) in return. ![]() ![]() ![]() ![]() Hopefully, we'll get this relay socket squared away (maybe tomorrow?) then get to test out the repaired DME, subsequently getting Yaz' '88 back on the road soon. Don't see this failure too often but could make someone chase their tales should they be t/s'g a problem, especially after dropping in a few relays right off the bat,..then on to other things (assuming the relay is not the problem). Yeap: the relay was NOT problematic yet the female side (receptacle) offered a failure. Aside from getting the DME relay socket repaired, something's telling me to doublecheck anything that could have caused this particular condition. Yaz stated that the female pin just crumbled upon disassembly. We just want to be sure that any overcurrent conditions are not present as this could have fatigued this female socket pin,..or water (shorting).....I don't know, just yet, but want to be cautious and thorough on the repair. I would state again: Loren found the DME to have failed. It happened to be an IC that had failed,..and not a failure he typically sees. As to the IC failure (itself), he determined that a few sensor inputs had failed on this IC, possibly being caused by a high voltage arc. Suggested that all spark plug connections be closely checked (seated well),..and make notice of cable dress. In any event, will follow-up once we get the DME relay socket put to bed. Again: A big thanks to Loren for providing this part. Thanks to all who have contributed here, as well. Let's see where this goes, eh? ![]() Would love to see YAZ driving that '88 sometime tomorrow!!!!!!!! Best! Doyle
Although it's been a week since the last update, Yaz and I finally timed our schedules to get to work on this. Today was the day. Of course, it ends up being on a morning after spending Patron Tequila time (shots) with friends so my spirits weren't what they normally are, but after sweating out a gallon of fluids, things started to come together........
Loren's pin fit perfectly and the receptacle was in good enough shape to reuse. BIG THANKS, LOREN!!!!! Loren had also repaired and checked out Yaz's DME previously so we were anxious to make sure it was good to go. DME pin repair was pretty uneventful and everything went back together ok (after triple checking the pin re-insertions). She fired right up, idled like a charm and ran perfectly for a 15-20 minute run. He let me drive (probably out of pity for me since my 89 is in the paint shop for restoration). Sure felt nice driving a 911 again after nearly four months of 911 abstinence. First time I've driven a Targa...his clutch is a good bit stiffer than mine, releasing at a higher point in the engagement and noticed that his shifter bushing is shot. Very tight car with great handling (although I didn't really toss it around). No "creaks" or moans whatsoever. Just a great feel! SO: moral of the thread story is to check your DME relay receptacle pins!!!!! One could throw DME relays at such a "condition" never achieving a start condition. VERY glad I had a chance to look at YAZ's ride, as I found a fuel leak right on top of the left side of the manifold! WOW,....after studying the situation, someone had provided a very incorrect repair of the T'd fuel lines going to the fuel rails. This could have been BIG trouble at any given point,..freaked me out. I'll probably start a different thread relating to this finding. In any event: SUCCESS!!!! Thanks to Loren for the DME repair, as well as getting the DME receptacle pin to us. Thanks to YAZ for trusting me to work on his car, and being quite patient with the few weeks it took to get her back on the road. As well, thanks to all fellow PP's who contributed their time, offering information. This is a great group!! BEST to all! Doyle
Rx'd a few PM's regarding DME repair sources. My apologies for not having posted a link to Loren's website. He can be reached here: Systems Consulting...Automotive Electronics
Best, Doyle
Dme ????
Hi my relay receptacle fell apart would anyone have this part laying around? the
plastic cover at the bottom of harness is missing ![]() thanks
"IGNITION LEFT OF STEERING" Alex Last edited by Alex973; 10-29-2015 at 04:21 PM.. |
Sorry for resurrecting this post, fist one that pop up while researching.
While changing my DME relay the receptacle fell apart, would anyone have the position of each 6 wires? Thanks
Bruno - - - - - - - 88 Granite Green Targa 04 Silver A4 Avant- 13 A3 S-Line 87 Black 944S -Gone |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
DME Wiring.
![]() ![]() ^^^^^ Here you go. Best, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Thanks Gerry,
Curious, where did you get the diagram ? Bruno
Diagram.
I bought it on line from:
![]() ^^^^^ Here is the official designation. http://www.cannell.co.uk/Manuals.htm http://www.cannell.co.uk/Manuals_Original.htm ^^^^^ These was my other source(s). Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 04-22-2017 at 04:50 PM.. |
ROW '78 911 Targa
cannell site is long gone for the manuals.
Here is a link you will like in my Dropbox. Diagrams are in it. https://www.dropbox.com/s/vaum8yzxavh8kzj/911%2084-89%20Porsche%20Workshop%20Manual.pdf?dl=0
And If you need the connector I think this is the one.
See timmy2's post below. Sorry did not know Pelican had it. Last edited by donporfi; 04-23-2017 at 12:23 PM.. Reason: Correction |
ROW '78 911 Targa
Pelican has the pins and the housing. Pretty darn inexpensive for the housing, pins not so much...
Pins: Electrical Pin Bushing 0035452626 - Genuine Mercedes-Benz - 003-545-26-26 | Pelican Parts Housing: Cable Connector Housing 0065458028 - Genuine Mercedes-Benz - 006-545-80-28 | Pelican Parts Need to search for the lid still.
I believe this is the correct lid for the 6 pin housing above.
Mercedes-Benz Plug Cover - 0095453028 - Genuine Mercedes I'm looking for a Carrera 3.2 DME relay plug, socket, which I believe Porsche lists as NLA. Will be awesome if this MB part works. Sure can't beat the price!
1978 SC Targa |
Pelican Parts Vendor
URO Parts Online Catalog for Porsche: https://apaindustries.com/catalog?make=2 Last edited by UROParts; 08-26-2019 at 12:18 PM.. |
I received the Mercedes socket and lid today from Pelican.
Mercedes-Benz Plug Cover - 0095453028 - Genuine Mercedes - 009-545-30-28-MBZ and Cable Connector Housing 0065458028 - Genuine Mercedes-Benz - 006-545-80-28 | Pelican Parts Perfect replacement for the Porsche Carrera 3.2 DME Relay socket. ![]()
1978 SC Targa |
