Pure Awesomeness
Transmission Problems?
I was getting a scrapping, tapping noise in my car recently. I started a "engine banging noise" thread about it.
Symptoms: -no noise when car first starts up and is driven for a couple of miles. -replaced all 4 CV joints this weekend (many thanks, Pete) -transmission fluid replaced about 1 year ago. Still full. There were some metal hairs in the plug, but no big chunks of things. -I'm pretty sure it makes the noise even when the clutch is disengaged but the wheels are spinning. -If I start the car and keep it in neutral and rev the engine I do not hear the noise. Even after I have been hearing the noise. In this case it doesn't depend on if it's hot or cold. -Shifting has been fine. The evil noise in question happens in all gears, but most noticeably when accelerating. -replaced coupler with one from the Coupling Whisperer about 1 year ago. -I have noticed that 3rd gear rattles my shifter when I first shift into it, under 3000rpm. Over that, and it's silent. -5th gear has been tricky to get into since I installed the new coupler. -Getting into reverse is hard to do 50% of the time; I sometimes have to put it back in neutral, let the clutch pedal out, and try again. It never grinds, its's just hard to find it, even when you pull to the right with force and search with force for the slot that heads towards your back. There are several other threads on here with sounds bits that were included. Yes, those sound clips sound like what I am hearing. But these threads don't have any follow up about what was the problem!!!! http://forums.pelicanparts.com/porsche-911-technical-forum/469218-915-transmission-gear-noise-help.html http://forums.pelicanparts.com/porsche-911-technical-forum/731844-help-wanted-carrera-transmission-noise-identification.html
1977 Porsche 911 |
915 Transmission noise
Well . . . from the threads you posted . . .
This is the rest of the story - - - http://forums.pelicanparts.com/porsche-911-technical-forum/701647-mystery-quiet-clicking-now-loud-clicking-gear-whining-trans-diff-pics-10.html#post7388549 He rebuilt the transmission and the noise went away . . . You may have a different problem - but this looks like the most likely solution. It is also possible that the shift coupler needs adjusting so the internal shift fork doesn't rub -- and perhaps change out the fluid with new Swepco 201 or other suitable type of your choice. Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine Last edited by Sboxin; 04-28-2013 at 07:42 PM.. Reason: Added info |
Sounds an awful lot like your problem. For anyone following along this is not a CV issue (all 4 are new ) not emergency brake related (disassembled and checked) not sway bar related. Random clicking/ popping noise (not repeatable). Have run it up on jack stands (no noise) drive it a few miles and noise returns. I'm stumped......Anybody have any thoughts?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
