bcgreen's Avatar
Vaseline on Fuch wheels
I have been reading about using vaseline on the Fuch wheels and would like to know if everyone has done that and what do you think? Are you still using vaseline?
Old 02-06-2013, 04:44 AM
ivangene's Avatar
I almost grabbed it last weekend - but ended up using a different method
something sounds goofy about this - but at some point I promise to give it a shot
Ed M
86' Coupe
Old 02-06-2013, 05:10 AM
Works beautifully.....
Old 02-06-2013, 05:19 AM
Fuch wheel cosmetic......
Apply a thin coat of vaseline or petroleum jelly on your wheels and you'll be surprised how they look much better!!!!!! I have tried these before about 20 years ago and still use it occasionally.
Tony
That is what my 1987 owners manual recommends
Old 02-06-2013, 05:38 AM
Banned
Doesn't it attract dirt?
Old 02-06-2013, 05:50 AM
Functionista
manbridge 74's Avatar
Not if you rub it in well and wipe off excess.
Old 02-06-2013, 05:59 AM
bcgreen's Avatar
Interesting, isn't it, with all our chemicals and technology over the years, and here we are using a product that was not designed for the automobile, that's really cheap.
Old 02-06-2013, 06:05 AM
cashman's Avatar
Just did it last week. Put on a thin film. Let it sit overnight, wiped it off before taking the rims to have new tires mounted. It does make the shiny parts look nice. Doesn't do much for the painted sections. As mentioned above it is recommended in the manual.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 02-06-2013, 06:34 AM
Funny, it brings back my slightly faded black centers and makes them look like new...or pretty close. It lasts a bit longer than I thought it would too. Probably 4-6 weeks depending on how often I wash the car.
Old 02-06-2013, 07:38 AM
group911@aol.co's Avatar
It is best to leave a generous amount on for a few hours as it takes time to soak it up.
Thanks,
Bob
group911@aol.com
Old 02-06-2013, 10:52 AM
Does this work on the polished aluminum wheels? So clean them first and then apply the jelly? Does this make the wheels look good for a long time?
Old 02-06-2013, 11:45 AM
Ova Day
msterling's Avatar
It is actually what Porsche recommends in the owner's manual. Works great and lasts a good while. The factory finish is a combo of paint on the center and anodized rim. Seems to work very well on both. I'm not sure about polished, uncoated wheels but it couldn't hurt to try.
It does not attract much dirt if buffed off. I have ancient jar that cost 12 cents!
88 Triple Black 911 Carrera Cab, ex Garage Queen
05 BMW E46 M3
21 Tesla Model 3 LR
08 BMW 328xi
15 Ford F150
Old 02-06-2013, 12:26 PM
Don't think so but not a big cost to try. It's to treat the anodized surface.
Thanks,
Bob
group911@aol.com
Old 02-06-2013, 12:40 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Yep the petroleum jelly is recommended on account of the anodized treatment of the "aluminum" areas of the wheel. So it's really not worthwhile to use it on wheels that have actual polished, non-anodized finish. Use quality metal polish on actual polished rims
Incidentally the PJ does do a nice job on the satin black paint! Just be sure to wipe it all off (several rags/towels needed) to avoid collecting brake dust & other dirts.
Kevin L
'86 Carrera "Larry"
Old 02-06-2013, 01:50 PM
dshepp806's Avatar
I use it on the tires (not wheels). Polish, for sure!
Best!
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 02-06-2013, 01:54 PM
86 ssinit's Avatar
Use it all the time works great.Best if after applying leave in sunlight comes out like new. Last summer used it on the targa top and it came out like new. Also used on the targa roll bar came out great.
1986 Porsche 911 Targa
1983 911 sc
2015 WRX
Old 02-06-2013, 02:01 PM
Vasoline provides the added benefit of a barrier to not allow much road grime, brake pad dust, etc. to grab onto the alloy base metal, even cat pee.
Wash off all with soapy water, then reapply.
Sherwood
Old 02-06-2013, 02:05 PM
dshepp806's Avatar
Exactly,..I tried it on my Carrera tail and it performed quite well. Different kinda stuff, for sure.
Have been in to this "Gummi-Fledge" stuff recently,..works nicely,..but vasoline has it's own character,...hope I'm not "chemically" doing a bad thing.....(uh-oh).
BEST!
Doyle
Middle Georgia
Old 02-06-2013, 02:58 PM
ejp ejp is offline
ejp's Avatar
I Vaseline my black anodized Fuchs every few weeks (up to a month). It makes my 25 year old wheels with 170k miles on them look better than the wheels on my 6 year old car. Buffing off the Vaseline can be quite laborious when it's cold out as it tends to harden. I don't bother with letting it sit and "soak in". I wash the car (including the wheels - with car wash soap), wipe the Vaseline on with terrycloth, and then buff it off with a fresh terrycloth.
Not only does this bring a nice shine to wheels, but it also protects them from water setting up and damaging the anodized finish. It's one of the best exterior car-care products that I've ever used.
-Ethan
Old 02-06-2013, 06:41 PM
