Oil Level Guage???
'84 Targa, oil level gauge just jumps from one extreme of the gauge to the other, I know the level is correct as i put in 10 quarts at the oil change just completed...Car is new to me so I have no history...I only drove it 20 miles last fall when I bought it, then put it on jack stands to do all the "over the winter work" I needed to do.
Car did sit for 3+ months with no oil in it. Any ideas as to what to look for?
Jay Traner 1984 911 targa 1923 STuTZ 690 Touring 2014 VW CC 2.0T 2021 Subaru Forester (Mrs) |
Must be shorting out. Check spade connectors at the tank behind the right wheel (remove , clean , strip and solder new ones is best , they are usually filthy) and check connector on back of gauge.
If still no joy you have to trace wiring or check the sender in the tank. But of course you know the only accurate way to check oil is with the car hot , level , resting 30s and with the dipstick?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L "They run best being run close to the ‘limit’ and done so regularly" - Grady |
that's the behavior mine displayed when the sender unit failed -- easy to access/replace -- the sender's a rheostat with a float attached -- easy to get to if you take off the passenger side rear wheel.
replacing the sender brought mine back to normal -- |
Member 911 Anonymous
Buddy with an 87 just called me from track day, his gauge just started to peg up while on.
I told him to check the connection at the oil level sending unit at the sump at rear wheel well. He checked and the negative wire was dangling, bingo ![]() Search for OLSU, I posted a tutorial on the diagnosis and fix. Jim
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 05-26-2013 at 10:15 PM.. Reason: damn tablet key board |
Thanks Draco! I'll do this ASAP....too late tonight but probably Wednesday...
You know the level (even when operating properly) will read correctly only when on a level surface, warm and at idle right? Sorry, but quite a few guys new to 911's think that it's supposed to read correct at all times. Cheers
Well, mine is accurate :P
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
RETIRED
So is mine...still doan trust it....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Mine is accurate....when the wire stays on.....
Had it fall off more then once
Ed M 86' Coupe |
Mine is very reliable. Even though it may move about, it is easy to tell when I'm a quart low. I think it's just a matter of getting to know your specific car.
David 1972 911T/S MFI Survivor |
Mine has been dead on with the dipstick for the entire time of ownership (60k miles and 7.5 years)
RETIRED
I always check the dipstick.....the gauge is like the VDO clock, un numbered volt or temp gauges. An annoyance. Not reliable at best and gives you dubious telemetry.
I've actually disconnected my gas gauge....hate looking at it, not linear and my latent OCD hates that. I use my odometer, that is dead nuts on per my GPS. Don't trust, verify or upgrade to better gauges. Back in the day, Porsche cut costs in some areas. Weber carbs get the premium on the used market. Zenith and Solex were better designs. They were dropped when Weber came in cheaper as an oem supplier. PMOs.....are modified copies using all three designs. Just my opinion, feel free to dispute. Aftermarket VDO gauges are pretty good. The ones supplied to early VWs and Porsche at the factory are bottem end.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 05-27-2013 at 10:07 PM.. Reason: Speelink |
AutoBahned
Dial 911
Jim, here's the info/thread that you sent me some time ago...I kept it - Very good! http://forums.pelicanparts.com/porsche-911-technical-forum/594192-oil-level-sending-unit-how-service-repair-maintain.html
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci Last edited by A horse with no name; 05-27-2013 at 11:05 PM.. |
was this for weight savings?
no need to pack around that heave electrical current flowing through those monster cables? ![]()
Ed M 86' Coupe |
RETIRED
It was inaccurate, read my post......again.....
I read your post Bob, I was just being silly
obviously I didn't think you would consider less electrical current an actual weight savings - would you
Ed M 86' Coupe |
