How can I feel 6lbs. of torque?
I don't have a torque wrench that will go down to 6 foot pounds one starts at 10 (3/8") and the other 30 (1/2"). The local parts place had a beam type but started at 5 foot pounds and was really a cheapo, I could move the pointer almost 10 pounds in each direction and it would stay at that reading.
So to torque down my valve covers how does anyone here do it without a quarter inch torque wrench? If they are marginally loose I can slightly re-tighten but if too tight I run the risk of leaking and maybe even warping the cover. I am installing turbo covers on the bottom and originals on the top. Terry
79 SC Minerva Blue ROW Non Sunroof Crank Window Coupe 3.0 SSIs, Backdated Heat COA: Passenger Side Mirror, Manual Antenna & Dunlop Tires |
just tighten them with a small ratchet. nobody actually torques vc nuts with a torque wrench, do they?
+1 for just doing it by hand. If I am thinking about the right bolts here they are perpendicular to the ground. You could always measure the distance from the center of the socket to the edge of the wrench then put an appropriate amount of weight on the end of the wrench and let gravity do the rest. Rounding to 9.81 M/SEC should do the trick.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
Schleprock
6 lbs is a bogus torque for the valve covers. I think the spec book is wrong/a typo. I'm not saying 6 lbs is bad, as the covers still do seal. But I know for a fact that you can torque them to 18 lbs and the covers aren't worse off for it.
I will admit the nice thing about using 6 lbs is that if they do weep a little bit, you have no problem (in my opinion) snugging them down a little more.
Kevin L '86 Carrera "Larry" |
Works for me. Jerry M '78 SC |
This post is exactly correct. The 6 lb/ft is a typo, where I can't remember. Rocker cover hardware is 8mm, and that needs 18 lb/ft. We did at least two 911 valve adjustments (sometimes three) every day for more than twenty years at Red Line. Every cover (except the early ones that used cork gaskets) was torqued in a crossing pattern, beginning in the middle, to 18 lb/ft. 99% of those cars were repeat customers over many years, and often 100,000+ miles, and we never had one leak.
Keep the Shiny Side UP! Pete Z. |
I have to strongly disagree with torquing these nuts to 18 ft/lbs. I you were to use very thin gaskets like the chain housings or no gaskets (just sealant) like the cam housing to head joint, then 18 ft/lbs would be fine. With the thick gaskets we use on the valve covers you will warp the covers and then they will be difficult to seal the next time they are removed.
I just snug them by hand without a torque wrench. You can always tighten them a little more if they leak. -Andy
72 Carrera RS replica, Spec 911 racer |
Paper Member
6 ft/lb = 72 in/lb. Buy a 3/8 torque wrench.
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Thanks all,
With the amount of knowledge here still something like a torque value can still be discussed. Any way I did a search about valve covers and that is what made me think I needed to be accurate here due to the crush washer metallurgy. So I'll just choke up on the ratchet make 2 tightening rounds starting from the center and just be sure they are evenly tightened all around. Sound good? Terry
Oh, BTW, 18 lb/ft of torque for rocker cover nuts will not warp exhaust covers. Early aluminum covers were inherently weak, that's why the factory switched to the heavily ribbed lower covers (usually called Turbo covers) - to prevent warping.
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 03-16-2012 at 06:12 PM.. |
Maybe don't need it but I had the tool so I used it ....I know they are the right spec though.. Steve |
Buy an inch/lb torque wrench and multiply by 12. Don't go with 18 ft/ lbs or you'll be milling your covers.
Jon |
AutoBahned
this is not rocket science, people...
Harbor freight has torque wrench can go down to 7lbs for cheap. Also, I use silicon gasket. It forgives better than paper gasket, so you can be a little off the torque spec and still ok.
Fat butt 911, 1987 |
Wash. State
Still some conflicting thoughts here. After reading my original search I thought of the aircooled motor expansion and contractions. lower valve covers with a pool of oil behind them threaded fastners acting like wicks, warp prone covers...........
My gut feeling was the turbo covers I am installing seem pretty robust, crush washers sealing the threaded area, thick gaskets for imperfections, polished mating surfaces, even torqueing medium pressure correct sequence......All should be fine. I'll torque down to 10lbs. install motor, drive and check for leaks. Unfortunately I will not be able to reinstall my motor until maybe June. I need a flywheel ($$$) and do some chassis work like brake hoses, fuel lines, heat flappers........... Terry
muck-raker
try putting 18 lbs on those red silicone rubber gaskets and see what happens
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
In direct answer to the OP's question, my answer would be "with a nice digital 0-20 foot-lb Tech Wrench"!!!!!!!!!!!!!!!! You can "feel" and read at the same time.....well,...kinda,..she vibrates as you approach programmed torque value and this is distracting to "feel"...but very informative.
Best! Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia Last edited by dshepp806; 03-17-2012 at 12:26 PM.. |
Factory gaskets,new nuts & washers 25 nm torque= 14-18 ftlbs & yes,I always torque everything& add torque seal when i'm done. No liability went you use the torque wrench.
Howard
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
