theiceman's Avatar
yeah thought so Bill, great for that ..
I just found the location on my car .. what a mo fo ... and to think i had the air box out last year grrrr...
yeah looks good, think ill leave it alone ... lol
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 05-12-2022, 08:24 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Has anyone ever considered running an additional ground strap from engine to negative battery terminal?
I just finished updating my fuel pump wiring and was looking at ground locations.
I have replaced the engine to chassis ground.
1979 930 3.4l Peter Dawe Motor, Bosch Twin Plug, Dual Bosch CDI, J&S Ignition Control, Webcam 158 , Maxed Flowtech Fuel Head, BL Adj WUR, Braided Fuel Lines, 009 Injectors, GT35R, TIAL .7with Turbosmart MBC, Fabspeed Long Neck IC, Fabspeed Headers, GT3 Style Pipe off turbo, Rennshift Short Shift, KEP Clutch Package, 8.41, Elephant Racing Suspension, Weltmeister Sway Bars, ??WHP, Innovate MTS Gauges, RPM, Switch,SplitSecondAIC 7th
Old 10-27-2022, 02:52 PM
Old fashioned Lithium grease is an alternative. I put some dielectric grease on my turn signal bulbs and they quit working, learned my lesson as to its not being appropriate where you want to make a good contact. It is excellent on spark plug leads and any boots over an electrical connection.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 10-27-2022, 03:28 PM
2,7 liter 1976
i have 2 straps hanging loose (engine compartiment)
anyone knows were to attach?
The one drivers side is to short to get to the wing nut
Old 05-11-2025, 05:25 AM
2,7 liter 1976
Old 05-11-2025, 05:27 AM
Originally Posted by jimmyjimmy View Post
left one may be ground for the overhead engine compartment light. not sure about the right one, maybe an old a/c ground
Old 05-11-2025, 03:53 PM
since we are on this topic - sorry my keyboard is malfunctioning. anyone have a list of what is attached to each ground. going out to check my bentley now but just because its in there does not mean i will find it lol
Old 05-11-2025, 03:55 PM
the wingnut you reference is used to secure the fuse panel plastic cover, not for a ground attachment.
Old 05-11-2025, 04:13 PM
A930Rocket's Avatar
^^^^ Do the grounds go to the engine lid at the hinges?
Old 05-11-2025, 04:31 PM
carreradpt's Avatar
Yes
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 05-11-2025, 05:41 PM
Yeah but where does the other end of these hinge grounds go. To a bolt on the engine tin? Valve cover?
Old 05-11-2025, 06:21 PM
Kraftwerk's Avatar
Always carry a bit of 80-ish grit sandpaper with your tool kit > Make 'fresh' grounds when needed!
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 05-12-2025, 05:14 AM
2,7 liter 1976
Okay,so no clear answer in fact
Old 05-13-2025, 09:31 AM
John W
There are two types of dielectric grease, a nonconducting one and a conducting one. Use the conductive one for electrical connections like bulbs.
Old 05-13-2025, 09:48 AM
Kraftwerk's Avatar
bonjour Jimmy jimmy, Some answers take time, I will check my car this weekend (its parked 10k from my home) but its an '83 and I don't recall seeing that curious ground-strap, ever.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 05-13-2025, 11:04 AM
the forward end is attached to the body between the accumulator and the fuel filter.
i do not see that ground strap on the passenger side. mine is a cab if that makes a difference.
Old 05-13-2025, 01:18 PM
