Odd one
We have a 1972 911T 2.4 injected that is bucking under acceleration . It has a fresh tune up. cap, rotor, points, plugs , timing, valve adjust . Also has a new perma tune ignition module .The linkage length for the fuel dist. have been set . All the hoses for fuel distributor warm up are in place . Heated air intake is in place and working .The enrichment solenoid is good and appears to be working . Idle switch is good . I have even tried richening up the mixture . I does not seem to care if its hot or cold .
Any thoughts ? Thanks Brian
Brian Thomas www.blackdogvintageracing.com http://www.facebook.com/pages/Black-Dog-Vintage-Racing/109693742477070 http://www.youtube.com/wrenchhead944 |
Fuel pressure? Low pressure could be starving the system.
1968 911S "Leona" Air goes in and out, blood goes round and round, any variation on this is a bad thing. |
I can't find a spec on the delivery pump . Does anyone have the numbers ?
Brian
Fuel pressure is 11.5 lbs at idle and drops to 9.0 under throttle. Any thoughts ?
Thanks Brian
Max Sluiter
That sounds low. IIRC it is supposed to be 15 psi.
Have you confirmed that the in-tank fuel filter screen is not clogged with rust or other gunk?
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Tank and its filter are spotless . Had the tank out . The fuel flow out of the line to the pump is great .
Brian
Max Sluiter
See here: http://forums.pelicanparts.com/4507132-post23.html
Thank you for the info . That helps a lot
Brian
We got a rebuilt replacement pump from Emalig . No luck . The pressure is still low and now I am at a loss as how to proceed .
Any help would be great . Thanks Brian
If the new fuel pump doesn't meet specs, return it for one that does. If they can't supply one that works, buy one from Pelican (new Porsche-sourced pump), or get one of the aftermarket pumps made to fill this application.
JR |
What changed, what I mean is if it ran fine then you replaced this and that and now it does not?
72 911 Although it is done at the moment, it will never be finished. |
Crusty Conservative
I would also suspect the Permatune & or the coil. Swap with known good units pretty easy to do..
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Ok Here is the story. We replaced the pump because of low pressure . The replacement brought the pressure up but not to spec .
I found the check valve in the return line was not keep the pressure up . After trial and error I got the pressure up to 15lbs . The bucking was gone but it still had a 4000 rpm miss. The Permatune module was bad . Put a different one one and it runs out good . Some fine tuning and its up for sale . Anyone want to buy a Porsche ?
