front wheel bearing, cannot budge the right front
I had a bearing go bad in my 84' 911. Got everything apart and started trying to work the hub off. Outer bearing is stuck solid to the spindle. Heat, rigged up a wheel puller to help. Will not budge. Ideas?
cutoff wheel and a chisel?
Rick 88 Cab |
Sounds like the bearing has spin-welded to the spindle. The strut itself may now be toast.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
Got it off, was a little scuffed, cleaned it up and got I all back together. All seems good.
Ask your neighbor for advice...
![]() He would help, but he's at work today...
2003 996 Carrera gone but not forgotten '88Carrera '96 993 '89 951 |
Platinum Member
![]() I have the left side left to do... I'm sure the weather will be crummy for that. |
Slide hammer, took a couple of minutes.....carefully. I spent a couple hours trying to be gentle. It just got to the point were there was no choice. I figured I would have to deal with whatever happened. The outside race was an adventure as it kept taking off the corner of my drift punches. I ended up grinding a special punch and it came out, helped to.. Heated the hub and froze the races and everything went back pretty easy. I did ask for some experienced advice along the way so I could avert as much potential damage as possible...thank to those folks for the assistance..
I have the the left side still in the freezer. I'm going to try and get it done this weekend. Last edited by gadjet; 10-29-2013 at 06:28 AM.. |
