Switched to higher viscosity oil and getting higher temperatures
Previous owner was running Mobile 1 10w30 fully synthetic. I drove the car pretty hard with this oil and the temp never got above 200.
I had some minor issues taken care of last week and had my mechanic change the oil to Brad Penn 20w50. The first time I drove it the temp quickly went up to around 9'oclock (225?). As I drove it went between 200 and 225 depending on the traffic. It seems counter intuitive to get higher temps with thicker oil. Is this normal? Anything I should watch out for? |
Tired Member
This should be interesting, so I'm subscribing. I'm thinking it may have less to do with the viscosity and more with the difference between a synthetic and dino oil.
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Heat is transferred to the oil by contacted with higher temperature metal parts and heat is transferred from the oil to the atmosphere at the oil cooler. The amount of heat transferred at the oil cooler would be a function of the flow rate through the cooler. Your oil temperature may be higher because the thicker oil has a slower flow rate through the cooler.
i dont have any personal experience, but this post on bobtheoilguy is consistent with your experience.
'Heavy oils can for sure cause hotter running temps. My empirical and vicarious experiences show thicker oils have more drag and cling, and can cause hotter oil! Something like temps 10 deg F cooler on the highway with 10-40 vs.20-50. ' Higher viscosity in summer heat?? - Bob Is The Oil Guy posts 2259028 and 2260060 you switched from 10-30 to 20-50 with a 25*F increase, and the other post switched from 10-40 to 20-50 with a 10*F increase. roughly, each 10 point increase in oil weight leads to a temperature increase of 10*F. admittedly a limited sample size... |
Not sure why, but when I went from valvoline 20-50 to brad penn 20-50, my car ran hotter and leaked like hell.
72 911 Although it is done at the moment, it will never be finished. |
I, too, noticed slightly higher temps when I switched to Brad Penn 20W50. I don't remember exactly what I switched from, but it was either Castrol 20W50 or Valvoline 20W50. Another data point.
Don Ivey '87 Carrera '13 Scion FR-S My Porsche tinks, therefore I am. |
Very interesting...thicker engine oils run hotter..just like Porsche thought in 2004....and recommended using synthetic 5w40, 0w40 and 5w50 engine oils retroactively to 1973 in all Porsche models.
BP is a very thick 20w50 HTHS is over 6…Takes more energy to turn a thicker oil and also wicks away less heat than a thinner oil would. Volume and flow lead to lower heat. Your oil pump is working a little harder and that translates into more heat. That's the over simplified explanation.
brant giere 2005 996 cup 1991 964 euro cup (Larbre #28- race 1987 carrera 3.2-street/de car 1962 Austin Healey 3000 |
This is correct, in these air-cooled engines flow comes first and extra viscosity is not necessarily better as in water-cooled cars.
Thanks for the feedback. When I mentioned the previous owner ran 10w30 in another thread people screamed bloody murder. While 10w40 or 50 was probably a better choice, 10w30 isn't that far off and seemed to perform well.
So with the thicker dino oil you're getting better protection but at the cost of higher temps? Seems like they cancel each other out. Is 240 about the temperature where you'd start to get concerned? |
Targa, Panamera Turbo
Yup, stands to reason...Perhaps the single most important characteristic of a lubricating oil is the viscosity.
The viscosity of a fluid is a measure of its resistance, it corresponds to the informal notion of "thickness". For example, honey has a higher viscosity than water. Viscosity is due to friction between molecules of the fluid that are moving at different velocities. When fluid is forced through a tube, the fluid generally moves faster near the center and very slowly near the walls. A liquid's viscosity depends on the size and shape of its molecules and the attractions between the particles. The thicker the oil the greater the restriction and the increase in shear which translates to increased temperature...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Reiver
OTOH the car ran very cool...normally 190-195 in 100 degree plus weather. Winter 10-40 am running 180- 190. Both BPenn. |
Senior Advisor
keep in mind the W measurement means WINTER or cold viscosity, the 2nd number is the viscosity at 100˚C. So you went from 30 weight to 50 weight at operating temperature. You want good cold flow (lower W number) but good or high hot oil viscosity that meets OEM requirements that the engine was designed to run with. I don't know what year engine/car we are dealing with but the oil either synthetic or dino should match the owners manual requirements. Also, what was changed/fixed by the mechanic. Might want to try the Brad Penn 10W30 oil and see what happens.
08 Cayenne Turbo |
I know there have been a lot of threads on what is the best oil but it seems the factory would know best about what kind of oil should go in our cars. Why would Porsche say to use synthetic if it was bad for our cars? What would they have to gain?
Kind of Blue
I noticed the same thing going from 15w40 to 20w50.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
Location: Living in my mind, but my tail resides in Mississippi.
Since Mr. Freeman switched Imogene to fully synthetic Motul 8100 X-cess 5w-40 I've also noticed the engine oil temperature does not rise as high as it did when running the Valvoline 20w-50.
dcjones56 - 1987 Porsche 911 Carrera - "Imogene" - very original, as per Butzi, engine rebuilt by Mr. Howard Freeman, acquired July 2010 - previous Porsche vehicles - 1998 Porsche Boxster, 2005 Porsche 997Carrera and 2009 Porsche Cayenne S. |
not sure if this is old news, but both shell and exxon/mobil have webpages which suggest specific oils for specific cars.
The Shell global homepage - Shell Global What's the right oil for my car? FWIW, for my car (1981 911sc), shell recommends 5W-40 full synthetic, and exxon recommends 0W-40 full synthetic. (the shell website doesnt include the 1981sc, so i used the 1984 carrera instead.) edit...castrol UK has a similar webpage and suggests a full synthetic, either 0W-40 or 10W-40 http://www.castrol.com/castrol/sectionbodycopy.do?categoryId=9024084&contentId=7073092 castrol US has a similar page which includes different suggestions for different climates, and suggests 20W-50 above 14* http://www.castrol.com/castrol/LubesSelector.do?categoryId=3240 Last edited by duncan1437; 11-25-2013 at 05:33 PM.. |
Reiver
One of the traits of a lubricant is to act as a heat transfer medium. The better the flow the better the heat transfer. Thinner oils will flow better and reduce temperature up to a point. That point is if it thins out too much the film strength is lost and friction will increase and the operating temperature will increase.
Follow the engine manufacture's recommendation as to oil weight and climate.
Dave K |
