tranny oil change interval
how often
Carl, |
Fleabit peanut monkey
1981 911SC Targa |
I do mine every 30k with SWEPCO.
Administrator
Annually.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Reiver
I've an '83 like yourself and about 30k or sooner ...I swapped in a euro with more HP and the later Carreras had an oil cooler on the 915 that I/we don't have.
I also run in AZ summer temps so I take that into consideration. Long hard drives in the summer equal an earlier change. |
also i check mine every year for full and how it looks
82 SC , 72 914 |
I know, I know... porsche gods are gonna be upset... forgive me.
Carl, |
I do it along with a 15K service. 6 pints of kendall/$30, better safe than sorry. I dump a lot of swepco out of them thar 915s. lots of positive response on how much better it shifts now.
Annual, for me....on a 89 G50,...Mobile One Delvac,..every years.
Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
86FlatSix
Bought mine March 2012 never knew what's on it. So I attempted to change the tranny fluid (DIY) last Christmas. I used 4 qts of Kendall bought from the host and noticed better shifting. I was thinking of doing it every 4th oil change or something like 12k since I already know how to do it.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
Under the radar
Interesting...
According to the '71 owner's manual, transmission fluid is to be changed every 12k miles. According to the '72 owner's manual, transmission fluid is to be changed every 10k miles. Bruce Anderson says change it every 30k miles.
Cars and Cappuccino
Get yourself a pump...or at lease a piece of hose you can squeeze the oil through...that angle into the case is a little flat.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
Go-Kart Mozart
Make sure you can get the fill plug open before you remove the drain plug. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
