69 Fuel Tank Sealing Rings
My fuel tank is seeping gas from the three fittings on the bottom of the tank. It looks like the copper sealing rings are the culprit. I found the parts diagram here and it looks like parts # 22, 24 and 28 are what I need. I was not able to find them on the catalog to order them. Do you know if these are available?
![]() I am also trying to find the copper sealing rings that go on the fuel inlet on the 40IDA's. I see we can get the complete Banjo replacement kit here from PMO but I would prefer just to replace the seals. Do you know if these are only available in a weber rebuild kit? ![]() I tried the local hardware store but have not found anything yet. If any of you have ideas where I can get these I am all ears. Thanks.
Keitho64 05 GTO 00 911 C2 64 Corvair Chicago Burbs; the Anti-Dragon... 11 turns in 318 miles |
AutoBahned
check Stoddards - they often get new parts made when out of stock
the other question is what sealant to use (if any) - Locktite 518, a Dow Corning product, or... |
