Originally Posted by OffCamber00 View Post
Beautiful! So CLEAN!!
1988 JDM Carrera 3.2, cat delete, Fabspeed exhaust, Euromeister replicas (Fuchs in the garage). LOVE IT!
Old 02-12-2014, 04:03 PM
WI wide body's Avatar
1986 Carrera Cabrio wide body.
Removed all the AC junk and the radiator under the engine cover. Can now see most of the engine through the cover louvers.
Old 02-12-2014, 04:11 PM
Brown747's Avatar
Before:
After:
1978 SC coupe #1834
Old 02-12-2014, 05:26 PM
getting there
-Wade
1972 Targa, nothing matching.
Looking for motor 6124265 and transmission 7720299
Old 02-12-2014, 05:33 PM
Before:
After:
Old 02-12-2014, 05:41 PM
1968 911 . a little soap and water
Darren E Hall
1963 Porsche 356B Coupe ,
1967 Porsche 911 Coupe
1970 Porsche 911E Coupe
1968 Porsche 911 Coupe , 1976 Porsche 911S Coupe
Old 02-12-2014, 07:05 PM
VW_NUTT's Avatar
Brown747. I'm very curious about your fan. Is that new or did you have it refinished. looks very nice. The previous owner of my car replaced it with a used one that looks good but its very dull, no cadmium/zinc coating left on it.
1984 Carrera
1985 Vanagon Westfalia
2009 Audi A3
2015 VW Jetta
2016 Sprinter
Old 02-13-2014, 11:45 AM
esonefour's Avatar
Before, removed a/c air pump exhaust system and fan when I got it home.
After,
Now, msd single pully and wevo...
Old 02-13-2014, 08:25 PM
El Duderino
tirwin's Avatar
I've noticed several of you have installed a metal fan strap that is drilled out. Is there any particular logic behind it ? (weight savings? is it really that much?)
Old 02-13-2014, 09:23 PM
esonefour's Avatar
I have a d-zug 917 key , weight all adds up . But I only did it as the original was in terrible condition.
Old 02-13-2014, 09:29 PM
Diss Member
Quicksilver's Avatar
Here is a pic showing the process of getting the engine cleaned up. I call this episode "The Rubber Explosion"® as pretty much every chunk of rubber in the engine compartment was toast.
I had the intake out because I found some cracked gaskets...
In the process of removing the intake I found the fuel line crimps were so gone that the hose would spin around like a bearing...
In the process of removing the gaskets I discovered the plastic intake spacers were crumbling...
In the process of rerouting the the vacuum lines I found one was cracked about a third of the way around...
In the process of reattaching the large (1") plastic breather hose I discovered that it was so brittle it fractured when I tried to reconnect it to the engine...
In the process of installing the brand new large breather hose I discovered it was actually made of very soft rubber so the old one was WAY beyond toast...
I did get the engine nice and cleaned (With some help. My back was completely out at this point...). Notice the nice block off plates for the intake that I built. Nice to have in the toolbox.
Once it was done it idled and ran better then it had in years.
Gee, I wonder why?
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 02-13-2014, 10:21 PM
Started assembly of some freshly powder coated tin tonight. Plus new engine carrier, bracket, and muffle bracket. Engine bay cleanup is well under way!
1982 911 Targa, 3.0L ROW with Webers
Old 02-13-2014, 11:10 PM
Originally Posted by m1franck View Post
Then, finally this will be installed at some point in the future;
Oh my god that's beautiful! May I ask how much all that carbon set you back? Did you make it yourself or order it? I've been playing with the idea of getting into composites, with engine shrouds, valve covers, fans, air filter housing and perhaps even exhausts for the old air cooled Porsches.. It's optimistic, I know, but it would be awesome if done right!
Life's too short for boring cars!
Old 02-14-2014, 12:56 AM
Flojo's Avatar
Originally Posted by Brown747 View Post
Befor:
After:
HA! astonisching!
I have an 99% near identical dejavue!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-14-2014, 01:05 AM
Certified User
billjam's Avatar
How clean do you want?
Bill
1988 Carrera - 3.6 engine with ITBs, COPs, MS3X
2024 Macan S
Day job ... www.jesfab.com.au
Memories: '68 912, '72 911T, '80 911SC, '84 911, '85 930, '86 930, '87 911, '21 Macan S
Old 02-14-2014, 05:00 AM
Flojo's Avatar
too red... looks like a baboons butt ;-)
Old 02-14-2014, 05:05 AM
Craig T's Avatar
Craig T
Old 02-14-2014, 06:58 AM
OffCamber00's Avatar
Originally Posted by Craig T View Post
DROOOOOOOOOOOOOOOOOOOOL
Mat P
1988 911 Carrera
Old 02-14-2014, 08:06 AM
Ferrino's Avatar
Awesome. How did you eliminate the charcoal canister - does your tank just vent to atmosphere now?
Old 02-14-2014, 03:01 PM
Flojo's Avatar
the white background really is a highlight contrasting the engine.
just perfect!
Old 02-14-2014, 03:22 PM
