cicsprog's Avatar
Question Fogged Headlights
My 1988 911 Carrea headlights have a haze when you look into them. The haze seems to be inside of the lens. My neighbors 1987 Carrea has the same problem. Any way to clean this - rubbing compound, simple cleaning by removing the lens and using window cleaner. or ????.
Old 09-04-2002, 03:42 PM
Remove the trim ring and the whole headlight assembly. DO Not try to remove only the lens. If you do not touch the adjustment screws, you headlight alignment will stay. Remove the rear bulb and then clean with alcohol, windex and some small wadding with a pencil or other tool. The haze is easily removed. Reassemble.
Old 09-04-2002, 03:54 PM
Don Plumley's Avatar
Yes. This is what I did: Remove the headlight, remove the bulb. Remove the dehumidification cartridge. Wash interior with non-ammonia Window cleaning stuff. Being very careful not to bend the interior bulb support, use a long stick (e.g. serving chopstick) and a soft cloth to clean the lens and reflector. Allow to dry. Replace dehumidification cartridge and remount. Admire clean, non-fogged headlights.
Don
Don Plumley
M235i
Old 09-04-2002, 03:55 PM
cicsprog's Avatar
Thanks for the posts. Amazing the amount of imformation for common problems here for us newbies. Thanks!
Old 09-04-2002, 05:26 PM
Question, there is a few British sites for Porsche parts that advertise lenses for cheap prices. Isn't it possible to remove the glass lens somehow? Or, is the grey sealant they used in the factory just not meant to be taken off?
1987 Carrera, Guards Red, Black (sold but never forgotten!)
1965 356SC Coupe, Silver on Red
Old 09-04-2002, 05:31 PM
Isopropyl alcohol works great to clean up the fog. If you use a swab, be very careful to avoid bending the metal arm that holds the bulb. If you do bend it, you'll never get it repositioned correctly again. If you try to reposition it too much with tweezers and forceps, it falls off. If you try to remove the lens to replace it, you'll find that that gray goop pretty much makes that impossible. Then you go out and buy H4's (which are great, by the way).
Before I tried a swab, I'd just pour some alcohol in,swish it around real hard and let it dry. I read on a thread somewhere that this works as well and can be a whole lot cheaper .
Argo
88 Targa
Old 09-04-2002, 07:36 PM
911 user
Milu's Avatar
NB Left hand drive and Right hand drive lenses are not the same.
Where once the giants walked now Mickey Mouse is king.
My other car is also a Porsche.
Old 09-05-2002, 01:24 PM
Never, Ever Do This
65_lincoln's Avatar
Cleaning H5 headlights - what a difference
I had never noticed the fogging of my headlights until I had my car parked next to a friend's '85, and what a difference! With much help from the Search function here, I found the advice (from John Walker as I remember, among others) to remove the assembly and clean the inside using Isopropyl alcohol (91%) and some dry rice to shake around inside, to do the scrubbing. It worked like a charm!
Be sure to remove the dessiccant pack that attached to the bottom of each lamp assembly first, once you have the lights out of the car. I then used my thumb to plug up that hole, filled the reflector / lens assembly with about 1/3 cup of the alcohol and probably 1 Tablespoon of dried rice (long grain brown rice, actually!). Shake it around for a while, then quickly pour out the fluid to get as much rice out as possible. I then rinsed the assembly out with clean cold water until all the rice was out, shook out as much water as possible, and finished with another 1/3 cup of rubbing alcohol, shaken around vigorously. I let them air dry overnight, and what a difference! See the photo below of my before and after.
Hope that this helps someone else.
John
1987 Carrera Targa, Lagoon Green
2012 Audi S4, Monsoon Grey
1965 Lincoln Continental convertible, Maroon--gone but not forgotten
Old 10-13-2008, 07:32 PM
I filled it half full of windex and shook the crap out of it.
Rick
88 Cab
Old 10-13-2008, 09:01 PM
Paul K's Avatar
Great thread- mine are cloudy too. Thanks guys!
Paul.
'85 Defender 90 V8 Station Wagon (mine), ‘16 Mini Cooper S Countryman All4, ‘79 Mini Moke Californian (hers).
'83 SC Coupe SOLD
'96 Carrera 4 Coupe SOLD
'89 Carrera Targa SOLD
Old 10-13-2008, 09:52 PM
Make Bruins Great Again
Por_sha911's Avatar
Chris, I have posted (along with others) numerous times how to clean these. You will want to consider using the search feature to mine a wealth of info already in previous posts.
Joe
Old 10-14-2008, 04:01 PM
H4's are the solution for that fogged-up design....
Mark
'88 Carrera GPW Sunroof Coupe
'82 SC Targa (RIP)
Old 10-14-2008, 06:45 PM
dshepp806's Avatar
Strong Isopropyl took care of my film,..clean it twice!
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 10-15-2008, 02:04 PM
Great thread. I going to attempt mine tomorrow? If I get hungry during the process is it safe to eat the rice? [img]
Old 06-11-2011, 09:18 PM
nabfa1's Avatar
The Rice worked like a charm !!!! Thank you The alcohol alone did not achieve very much . The combination is key .
Old 03-09-2015, 07:37 AM
Driver, not Mechanic
Resurrecting the thread after Bay Area rains. I have H4s and they still fogged up. I removed them to air them out, which helped, but when I put one back, it fogged up again. Should I take a chance and disassemble the lens to wipe it?
Old 10-17-2016, 03:04 PM
creaturecat's Avatar
might need a new seal. that headlight.
Old 10-17-2016, 03:41 PM
I think with H4s the seals only prevent the rings from touching the fender metal to metal. H4 housings aren't sealed. There are vent holes in the housing, the reflective cone itself doesn't touch the housing, and there's a drain hole in the fender...
Old 10-17-2016, 06:20 PM
Does the rice/ alcohol technique really work?
Does the rice leave any residue? Thanks for the guidance.
Old 06-19-2017, 01:33 PM
After cleaning the H5 lights, you might want to replace the Humidity Absorbent 911-631-968-00.
Old 06-19-2017, 03:16 PM
