1984 Targa Carrera
Quick Question
Hello!
I started my car last night, and I could here a slight howl or whine coming from the rear passenger side of the car as it sat at an idle. When I pressed on the gas pedal, the sound would go away, and once the car was warmed up, I didn't hear it again. Any ideas on what this might be? Thanks for the help.
1984 Carrera Targa |
Sounds like you need a new fan belt or it needs to be adjusted
Ernie |
It may be the valve off the oil tank that controls air flow to prevent throttle body icing in cold temperatures. I have heard that it whines or whistles when it is failing.
Ed 1973.5 T |
1984 Targa Carrera
I will check the fan belt, but I don't think that is the issue. I also check the valve at the oil tank!
Thanks for the input!
