3.2 pings even with 91 octane
I have a stock 3.2. No mods at all. Maybe 10k miles on full rebuild. Passes CA emissions. Runs well - but - it pings on hard accel at 5k rpm with oil temp at 200F with 91 octane. Is this common?
Rescuer of old cars
No, I don't think so. Mine has never pinged that I've heard, not ever.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Definitely not common! Check for aftermarket chip and possible lean condition due to vacuum leaks.
Is this pinging from one tank of gas? I've gotten a bad tank of gas before that has resulted into some pinging that was not typical.
If it is typical, then, yeah, you have some sort of issue.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
Check the operation of the Wide Open Throttle switch. That was my issue. Bad solder joint inside. Ken
Ken in Greer, SC 88 Carrera Coupe 98 C2S Coupe |
Chain fence eating turbo
Good ideas - thanks all.
