Recreational User
Getting oil stains off your driveway.
I know there are a thousand ways to clean oil off your driveway, but I just had to post this new-to-me solution. Normally, I clean-off oil stains by spraying the spots with engine degreaser or carb cleaner. Neither has ever fully removed the stain, but I assumed nothing out there really could... especially older stains. Well... today, I was out of both of these products, so I tried some CRC mass airflow sensor cleaner that I bought from AutoZone for my Tacoma. WOW! It instantly removed new AND old stains with no scrubbing!
I couldn't believe it. I'm sure it's not environmentally friendly and it's probably killed a few of my brain cells, but I can't recommend it enough. It's definitely worth trying if you've been stumped by everything else.
'88 924S - Stone Grey Metallic |
Platinum Member
I've had good results with Oil Eater, as long as you catch the spill soon.
This Way Up
I had great results with something called Pour n Restore. Even works well on old stains
Data Farmer
embrace the stains!!!!!!
Recreational User
I do, I do! It's the wife that doesn't appreciate them.
I've had good luck with spraying it down with WD-40 and dabbing it up with a paper towel. Seems to even get down into rough concrete. surfaces.
1978 911SC (not black, Mocha Brown) |
Sprinkle dry cement powder over the stain, leave for a couple of days and then simply sweep it up.
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
74MetBlueTarga
Mineral spirits and cat litter.
Flyin' blind
I recently used my citrus-based bicycle degreaser on a fairly fresh spot on my garage floor…. worked like a charm. Added bonus is that it's biodegradable so I don't mind watching it run down the street when I hose it down.
Thom 89 Coupe |
Eva
It looked like the spots were coming out(rainbow runoff water) but were still there when it dried. ![]() I'm going to try mineral spirits and kitty litter.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Oil eater and kitty litter. I pour oil eater on the stain and scrub with a push broom, then spread the kitty litter. The kitty litter absorbs the fluid, which seems to break down and evaporate. allowing the kitty litter to be used over & over again.
Oil eater is non-toxic/environmentally safe regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
RETIRED
Kitty litter, then grind it in with a flat soled pair of boots.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
its important to note what you are trying to get the stain off of.
cement driveway or tarmac ( i think you guys call it ashfault or something ) may requre different treatments. i have amazing results with just tide HE cleaner ( the blue stuff ) . also amazing for just getting hands clean after working on the car
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
