need eccentric bolt for rear toe
I believe I need to acquire an eccentric bolt for setting rear toe.
My car has the Smart Racing rear sway bars and they attach with a bolt that replaces the rear toe bolt. The idea is you set the rear toe, then remove the toe bolt and replace it with the Smart Racing bolt.
I don't believe I have the rear toe eccentric bolt. I don't see that Pelican sells this bolt, nor does it look like they sell the one for camber adjust, either. They do sell the washers and nuts for the bolts.
Am I searching incorrectly on PP?
Separately I see that PP sells a rear toe setting "tool". But, its not a bolt as it doesn't (seem to) have threads. I haven't done a rear alignment before so I may be missing something in my understanding.
Old 07-24-2014, 11:35 AM
Toe In adjusted bolts.........
So you need two (2) toe-in adjuster bolts? I think I have an extra set in the garage. PM me your address.
Tony
Old 07-24-2014, 02:03 PM
If Tony does not have what you want, search Pelican with 901 333 133 05. It is there. -04 is the camber bolt.
Old 07-24-2014, 04:23 PM
Cancelled shipment.........
Brian,
I was preparing the padded envelope with your address when my son advised (instructed) me to save them for his track car I am building for him. You know you are old when your youngest child tell you what to do. Sorry to cancel the shipment.
Tony
Old 07-24-2014, 08:24 PM
Wer bremst verliert
JohnJL's Avatar
Our host should be the first choice of supplier, but I am also quite sure Elephant has complete hardware replacement sets.
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 07-25-2014, 04:22 AM
Tags
eccentric bolt , rear toe
