Grappler
Rodsrsr's Avatar
I nominate for build of the year!
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 07-18-2017, 08:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #201 (permalink)
jarrodblake's Avatar
Thanks!
Well the 993 steering column came in and the splines are the same!
Test fit.
Im had to notch the frame to get the angle correct.
As you can see the angle is just a little off I also had to use the sock steering column bracket as the bolt spacing is different.
First cut Killed a hole saw and 3 drill bits.
Second cut with the plasma cutter.
Old 07-27-2017, 12:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #202 (permalink)
Now I need to decide how i'm going to mount the rear of the steering column from the top from the fire wall or from the bottom? But I suppose it depends on what pedal box I use.
Something I did not know about the 993 column there is a spline for both the new and old style steering wheels
More ducting work.
Now I get to figure out how to A. mount the steering angle sensor or delete the PSM system.
Old 07-27-2017, 12:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #203 (permalink)
Welded in a brace tie in as the trunk pan does not sit as far back.
Next is templates for the fuel tank cover. And center fill.
Old 07-27-2017, 12:49 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #204 (permalink)
Eng-o-neer
Tremelune's Avatar
Holy cow.
Old 07-27-2017, 07:09 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #205 (permalink)
Originally Posted by Tremelune View Post
Holy cow.
Things can get a little out of hand when I am left unsupervised.
I made a bit of progress this week.
The ducking is in place.
I made a crossmember to go in front of the gas tank. There is one in the 996 as well.
My gas cap bung came in for my center fill Thanks to Dave at TRE! Now I just have to figure out what box I put the gas cap in. I also ordered a 2" Tri clamp the bung as sitting on a 4-2 reducer and go to a 2" flange into the poly tank. I will be making a sheet metal cover for the gas tank the plan is to cut the hole for the filler neck just to fit the Tri clamp flange so I can remove the 4" filler neck and drop the tank out of the car through a 2 3/8 hole instead of a 4" hole.
70 911E Rip, 01 Boxster Rip, 83 911 Bastard build http://forums.pelicanparts.com/porsche-911-technical-forum/824065-1970-911e-yard-find-8.html
91 MX5, 78 Cj10 Rat Rod, 02 WRX
Old 08-10-2017, 10:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #206 (permalink)
The front trunk area is done for now there is a bit more work to be done but for now i'm moving on.
For now I'm going to leave the ducting lids removable. however I have not decided if I want to weld the VIN number panel to the lids or if I want to weld the panel to the cross member.
At some point I need to design a brace that connect the suspension crossmember to the old suspension front mounting points and integrate a tow hook.
I also started on my gas tank cover.
Old 08-10-2017, 10:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #207 (permalink)
Under the radar
Trackrash's Avatar
This is one epic project. Great progress so far.
Gordon
'71 911 Coupe 3,0L outlawed
Old 08-11-2017, 09:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #208 (permalink)
I'd love to see you bring this in for a warranty repair. Just point to your vin when they ask you what's going on.
89 Carrera 3.4
"There is a right way to go around a corner - it's called the line." -- PCA DE speaker
bryteside.com - good things happen.
Old 08-11-2017, 12:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #209 (permalink)
Every car guy knows the legendary internet story about the man who built a Lamborghini in his basement. Are you that guy's cousin?
Look forward to seeing the continued evolution of the car.
Old 08-11-2017, 09:23 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #210 (permalink)
Crusty Conservative
silverc4s's Avatar
Wow. Just wow.
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 08-12-2017, 05:30 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #211 (permalink)
Ubi bene ibi patria
Hawkeye's-911T's Avatar
Amen!!
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 08-13-2017, 10:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #212 (permalink)
I haven't seen your thread since around page two.
Sure wasn't expecting to see this turn of events.
Very creative solutions and craftsmanship at play here.
Good luck in bringing it to a good conclusion .
You got this!
Cheers Richard
Old 08-13-2017, 11:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #213 (permalink)
Having made my funny about your vin, you may actually want to swap it out for the sc vin. It will save you some headaches for obd-ii diagnostics on your inspections.
89 Carrera 3.4
Old 08-14-2017, 09:02 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #214 (permalink)
Grappler
Rodsrsr's Avatar
I gotta admit, I'm eating crow on this one. I was one of the doubters when this thread started with the rusted out body. OP clearly has some serious building skills.
Grappler
Know Gi / No Gi
Old 08-14-2017, 09:31 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #215 (permalink)
backdate it, make it a longhood coupe. this is insane.
Old 08-14-2017, 02:50 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #216 (permalink)
Thanks!
HaHa I plan on bringing it in when it's finished Maybe ask them to do a coolant flush on a 83 911 or maybe complaining about a suspension clunk and get them to put it on the lift.
I wish!
Originally Posted by silverc4s View Post
Wow. Just wow.
Thanks!
Originally Posted by Hawkeye's-911T View Post
Amen!!
You got this!
Cheers Richard
Thanks! I wish I had took more time planning out the build for the 70E and came to the same conclusion to build it the same way I am building the 83 911. I probably would have finished it by now that said it's been a learning experience.
I plan on keeping it a 83 911. There are no inspections of any kind in indiana and I really don't like the idea of swapping the vin from the 70E. With that said at this point with the modifications it's not like trying to pass it off as a 70 911 would help it in value.
You may have been and in a way you were right to as I did end up giving up on the rust bucket.
Thanks that is the plan it will be backdated and it will be a coupe. It will be something like a 73 RSR on steroids X10.
Old 08-14-2017, 09:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #217 (permalink)
My Tri clamp came in the other day. Now I just need to wait on my custom flange to come in. before I start fitting the filler neck.
I also finished my templet of the gas tank cover yesterday. I will hopefully I will start transferring it over to the sheet metal tomorrow.
Old 08-14-2017, 09:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #218 (permalink)
Well no real progress has been made since I past posted a did make the templet for the gas tank cover. But I have been messing with a few other projects and bought a few more toys. I sold the Rat Rod and bought a car hauler/ tow rig it needs a bit more work than I thought it was getting dark when I picked it up...
So what little progress I had made last month.
[IMG]IMAG0756 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0757 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0758 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0759 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0760 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0766 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0768 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0769 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0770 by jarrod vanwinkle, on Flickr[/IMG]
Old 09-22-2017, 09:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #219 (permalink)
[IMG]IMAG0773 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0790 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0793 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0791 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0792 by jarrod vanwinkle, on Flickr[/IMG]
obviously it's not going to sit that high I just have to wait until I cut the hole in the hood.
[IMG]IMAG0794 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0796 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]IMAG0798 by jarrod vanwinkle, on Flickr[/IMG]
Old 09-22-2017, 09:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #220 (permalink)
