Grappler
I nominate for build of the year!
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Thanks!
Well the 993 steering column came in and the splines are the same! ![]() Test fit. ![]() Im had to notch the frame to get the angle correct. ![]() As you can see the angle is just a little off I also had to use the sock steering column bracket as the bolt spacing is different. ![]() First cut Killed a hole saw and 3 drill bits. ![]() Second cut with the plasma cutter. ![]() ![]() ![]()
Now I need to decide how i'm going to mount the rear of the steering column from the top from the fire wall or from the bottom? But I suppose it depends on what pedal box I use.
Something I did not know about the 993 column there is a spline for both the new and old style steering wheels ![]() ![]() More ducting work. ![]() ![]() ![]() ![]() ![]() Now I get to figure out how to A. mount the steering angle sensor or delete the PSM system.
Welded in a brace tie in as the trunk pan does not sit as far back.
![]() ![]() ![]() ![]() Next is templates for the fuel tank cover. And center fill. ![]()
Eng-o-neer
Holy cow.
Things can get a little out of hand when I am left unsupervised.
I made a bit of progress this week. The ducking is in place. ![]() ![]() I made a crossmember to go in front of the gas tank. There is one in the 996 as well. ![]() ![]() My gas cap bung came in for my center fill Thanks to Dave at TRE! Now I just have to figure out what box I put the gas cap in. I also ordered a 2" Tri clamp the bung as sitting on a 4-2 reducer and go to a 2" flange into the poly tank. I will be making a sheet metal cover for the gas tank the plan is to cut the hole for the filler neck just to fit the Tri clamp flange so I can remove the 4" filler neck and drop the tank out of the car through a 2 3/8 hole instead of a 4" hole. ![]() ![]() ![]() ![]() ![]()
70 911E Rip, 01 Boxster Rip, 83 911 Bastard build http://forums.pelicanparts.com/porsche-911-technical-forum/824065-1970-911e-yard-find-8.html 91 MX5, 78 Cj10 Rat Rod, 02 WRX |
The front trunk area is done for now there is a bit more work to be done but for now i'm moving on.
![]() For now I'm going to leave the ducting lids removable. however I have not decided if I want to weld the VIN number panel to the lids or if I want to weld the panel to the cross member. ![]() At some point I need to design a brace that connect the suspension crossmember to the old suspension front mounting points and integrate a tow hook. ![]() I also started on my gas tank cover. ![]() ![]() ![]() ![]()
Under the radar
This is one epic project. Great progress so far.
I'd love to see you bring this in for a warranty repair. Just point to your vin when they ask you what's going on.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
Every car guy knows the legendary internet story about the man who built a Lamborghini in his basement. Are you that guy's cousin?
Look forward to seeing the continued evolution of the car. |
Crusty Conservative
Wow. Just wow.
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Ubi bene ibi patria
Amen!!
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke "As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras |
I haven't seen your thread since around page two.
Sure wasn't expecting to see this turn of events. Very creative solutions and craftsmanship at play here. Good luck in bringing it to a good conclusion . You got this! Cheers Richard |
Having made my funny about your vin, you may actually want to swap it out for the sc vin. It will save you some headaches for obd-ii diagnostics on your inspections.
Grappler
I gotta admit, I'm eating crow on this one. I was one of the doubters when this thread started with the rusted out body. OP clearly has some serious building skills.
backdate it, make it a longhood coupe. this is insane.
Thanks!
Thanks! Quote:
Thanks that is the plan it will be backdated and it will be a coupe. It will be something like a 73 RSR on steroids X10.
My Tri clamp came in the other day. Now I just need to wait on my custom flange to come in. before I start fitting the filler neck.
![]() ![]() I also finished my templet of the gas tank cover yesterday. I will hopefully I will start transferring it over to the sheet metal tomorrow. ![]() ![]() ![]() ![]()
Well no real progress has been made since I past posted a did make the templet for the gas tank cover. But I have been messing with a few other projects and bought a few more toys. I sold the Rat Rod and bought a car hauler/ tow rig it needs a bit more work than I thought it was getting dark when I picked it up...
So what little progress I had made last month. [IMG] IMAG0756 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0757 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0758 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0759 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0760 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0766 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0768 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0769 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0770 by jarrod vanwinkle, on Flickr[/IMG]
[IMG]
IMAG0773 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0790 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0793 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0791 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0792 by jarrod vanwinkle, on Flickr[/IMG]obviously it's not going to sit that high I just have to wait until I cut the hole in the hood. [IMG] IMAG0794 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0796 by jarrod vanwinkle, on Flickr[/IMG][IMG] IMAG0798 by jarrod vanwinkle, on Flickr[/IMG]
