Location: the bluest city in the bluest county in the bluest state by the bluest ocean...did I mention the blue skies???
Help with garage lift placement….
I have a 3 car garage with 12' ceiling…. Little over 30' wide and 24+' deep. It has one 16' "double" door and one 8' "single" door. There are no walls or support posts anywhere in the garage floor area….all open.
I am planning to install a two post lift. Should I place it in the middle space (inside the double door opening) or, on the side with the "single" door ???? Anyone else do this??? or anyone have an 'educated' opinion??? Thanks in advance.
Greg....PCA, 356 Registry, 912 Registry 1977 911S Targa with 3.2...1960 T-5 coupe 1968 912 coupe, that's 32 P-cars, so far... 1990 Chevy 4x4 2500 pickup (with 255K & still rockin') |
I would consider if you also use it for parking or is it to be a dedicated shop. Where are things like work benches man doors, etc . compressor electric panel,windows. Without knowing much else I would probably put it inside the 8ft door at one end and save the 2 car door area for car parking.
1980 911 SC 3.6 coupe sold 1995 993 coupe 1966 Mustang Shelby clone 1964 Corvair Spyder Turbo gone 2012 Boss 302 |
But, if it was me, I would put it in the middle and with benches on each side. The two 8' bays for car parking and the middle one for working on cars. In the winter you can keep a 4th car in the garage by storing one up on the lift and a second car under it.
My lift is is a 20 foot wide garage room that is 36 feet deep. With benches on each outside wall, there is not any excess space.
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries! 1974 911 RUF Clone ('85 3.2; '86 915) 1974 914 ('87 3.2L & 915 transaxle) 2005 Boxster (Base car) Guards Red. |
Thats the setup I had in Montana. Just make sure you have a enough space on the outside wall.
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor Last edited by cary; 08-06-2014 at 05:58 AM.. |
Cary 77 Carrera RS w/3.2 #59 73 914S 2.0 AG 73 914 1.7 Driver ( daily driver, under complete rustoration ) 74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor Last edited by cary; 08-05-2014 at 07:13 PM.. |
Lift placement
I would put it inside the single space door if it will fit. Most lifts will require 11-12 feet of space from outside of post to outside of post. If you put it inside the 16 foot door, you probably will not be able to get two cars in that side. Of course, you could put one car up on the lift and park a second one beneath it. Putting the lift inside the small door will let you park 4 cars in a 3 car garage!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
fried cook, but his garage is only 30 feet wide, with 2-8' doors and a center 16 foot door. It does not add up because 2-8' and a 16 add up to 32 feet of garage door width in a 30' garage. 11 1/2' of lift with an room on the wall side will take up much of his 30'? wide garage.
83 911 Production Cab #10
I just moved my scissors lift from dead center of the single door to a foot to the left so it give me more room on the passenger side between the car and the wall. Its 25 x 20.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Good thread. I am working on building a 30x50 garage with 16 ft center and hope to have a 2 post lift too. I was thinking of putting the lift in the far back left corner of the garage. How much space should I leave around the lift area to be a practical and comfortable work space? I want a few benches on the back wall but not sure about the side wall where the lift is.
1982 SC "Spooky" 1961 VW Single cab truck 1966 VW Deluxe Hard top |
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
I just went through this with my 2-post / 3-car garage. It really helps to get the size specs of a lift that meets your requirments and lay it out on graph paper with your shop measurments drawn out. The narrowest 2-post I could find is the Mohawk A-7. Thats what I went with and its a total beast. I love it.
I would put it in the single bay if you have room. As mentioned, you need about 10-12 feet for the max width of the lift. But usualy they also require being placed about 8-12" min from the wall. If you have at least 3 feet from the edge of the garage door cut-out to the wall, and another 2-3 feet between your single and double door you probably can swing it without encroaching on the 2-car space. If you put it in the dble car space it will certainly take up both sides of useable parking space. You also need to consider that the posts cannot be within 12-24" of a crack or floor seam (specs vary with manufacturer). Also the electric supply and the fore and aft location of the posts needs to be figured out. When it comes down to it, there are a lot of considerations to go through before the lift gets put in. Last edited by 911_Dude; 08-06-2014 at 06:56 AM.. |
I installed mine in the single door space of my shop, right next to the wall - I'm about 12" off the wall, enough to squeeze by and plenty to work on the car. If I know I need to do 'right side' car work, I may drive the car in a little to the left to allow a few more inches of room, but it's fine.
+1 on remembering to run power in a good location! I ran the power high on the wall, so it just loops to the top of the lift out of the way. I also ran an air line over to the lift alongside the power conduit, and I have a retractable hose reel bolted to the top of the left post -- puts it right in the middle of the shop for easy access, yet retracts out of the way. Chuck.H '89 TurboLookTarga, 380k miles |
Lift
Pm me with you email and I will send you a pdf of a floor plan of my 7000# Radial Lift. I wanted to be able to lift my F150 and my sons 3500 series Government Motors dually.
I cannot figure out how to attach a pdf to this thread. To walk around the outside of the posts which you will need to do if you are working on tires, wheels, brakes etc where you want the vehicle just a couple of feet off of the floor, you need 18" to 24" outside of each post. Then to have work benches on the sides and available when you have the vehicle up in the air, you need another 24 to 30" on each side. I added these up (12' lift post width, and 4' on each side of each post) and came up with 20' of width. So my "car work on bay is 20 feet wide. You can get buy with a little less that 24' of depth, but I would do my best to allow 20' of width. If you place one post next to a wall, you will not be able to get past the post when you have a vehicle one or two or three feet off of the floor. Just my 2cents worth.
daleflesburg i just messaged you for a PDF of your garage layout. I would love to keep the lift near the side wall but you did point out a good point that if you sit down and work on the vehicle at a low level that you would need more room to move. I too have a big vehicle to work on to a 03 suburban. I need to plan on working on it in there on a lift too. How far off the front of the vehicle would you need to work on it to the wall or bench? Good thread everyone
Very helpful.
