77 911 shift gate spring?
Howdy, The little spring for the shift gate is broken. It appears the "Carrier Plate" must be replaced as a unit. The lever looks like a short shift modification was done. Will a stock replacement part fit? Can these springs be repaired? You got one for sale?
Old 09-18-2014, 01:06 PM
If you can replace the large rivet that holds the assembly together (drill through and chisel), I've got a few of these springs removed from carrier plates as well as complete, used carrier plates. Let me know via PM.
Sherwood
Old 09-18-2014, 09:51 PM
