Fan deflector repair...
I have a couple engines I am rebuilding right now. The forward cover for the alternator inside the shroud was weak and the vanes used to deflect the air towards #1 and #2 cylinders were worse. The vanes are some composite phenolic material... really strange. Later versions of the vanes are riveted to the underside of the shroud. My vanes are riveted to the plastic cone shaped housing on the front of the alt/fan assembly. This is what I started with...after two coats of clear lacquer to lay the fibers down.
Not sure what the material is, but there are definitely fibers
I laid up fiberglass molds
Separated
And trimmed
Glassed an additional layer at a 45 degree angle
Cleaned up the plastic cone
And trimmed and mounted
Done and installed in here...2.7 RS spec MFI for the 914-6...almost done.
Old 10-11-2014, 10:26 PM
Little further along...
Finishing up the MFI and waiting for Pacific to return my oil cooler.
Speedo
BTW...not planning to reproduce these
Old 10-11-2014, 10:31 PM
Send a message via Skype™ to Porboynz
Oh my, that's just so pretty.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 10-12-2014, 11:41 PM
