Originally Posted by wicks View Post
Question about the shrader valves - I removed all of them and got a reading of zero, then put them all back in and get a proper system pressure, but opening the valve to WUR I get no change - stays at system pressure. I can’t figure how this behavior could happen - seems like with no valves in lines I should be able to see both system and control...any clues?
Schroeder valves are just one way valves. If you leave it in, readings will be locked at the highest registered reading. Take them all out...
I have been using the HF kit for 4 years on and off with no issues...
Old 11-24-2018, 10:07 AM
Ok will try that again. With them all out, I got zero pressure on the gauge...
Old 11-25-2018, 12:21 AM
I had a similar problem with the HF gauges. I had to also get rid of the quick disconnect valve(s) on the gauge side of the T-piece and if I remember correctly I ended up connecting the gauge directly to the T-piece.
Old 11-25-2018, 08:07 AM
There is a spring and seat on the other end of the fitting as well, pull that also
Old 11-26-2018, 07:36 AM
Super Moderator
nize's Avatar
resurrecting this old thread since i need to test the fuel pressure now. the kit referred to here seems to be the $90 'master test kit' with skus 63727, 97706, 62788, 95319 here:
https://www.harborfreight.com/Master-Fuel-Injection-Pressure-Test-Kit-63727.html
anyone know if the cheaper $25 'fuel injection pump tester' kit with skus 62623, 92699 also works?
https://www.harborfreight.com/Fuel-Injection-Pump-Tester-62623.html
edit: nevermind, i just noticed it states the cheaper $25 kit does not fit bosch or CIS-jetronic. ignore. thanks.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 04-12-2020, 04:32 PM
^ You're using it to test CIS Jetronic? Yes, you will need the more expensive kit.
It worked well enough for me. Funny thing is I thought the hoses and connections were the good part of the kit, the gauge itself was the weak point. But as I say, a multimeter and wideband O2 sensor with a test pipe, and you have all you will ever need to fix anything on your motor.
Old 04-12-2020, 05:45 PM
At this time the HF "Master" fuel injection service kit is $300.
Is this the same kit you all got back in the day for <$100?
https://www.harborfreight.com/master-fuel-injection-service-kit-64938.html
Andy
1987 944T w/LS1
1981 (12/1980) 911SC
Old 09-07-2024, 02:08 PM
Cory M's Avatar
The Maddox Deluxe kit is still $90 at HF. It does what you need.
Old 09-07-2024, 03:51 PM
Andy
The one you posted a link for says it includes
Adapters for Honda, Ford, Chrysler, Jeep, & GM, Schrader Fittings for Ford EFI & MPI, Chrysler, Jeep, GM, (36) Specialized Fittings
I'd pass, and not merely because it's $300; it doesn't mention CIS, European - or include brands that used CIS like VW, MBZ etc. Which seems like a red flag...
This seems more suitable - it mentions fittings for "European" and "CIS": MADDOX Deluxe Fuel Injection Service Kit
For $69, I think this is the one I bought from Amazon for CIS way back when: BETOOLL Pro Fuel Injection Pressure Tester Kit Gauge 0-140 PSI
Although I later sold it - and when I needed one again, I bought the digital gauge version the next time.
'77 S with '78 930 power and a few other things.
Old 09-07-2024, 04:01 PM
Thank you both, I'll pick up the Maddox Deluxe tomorrow!
Andy
1987 944T w/LS1
Old 09-07-2024, 04:57 PM
My experience with these hasn't been very good. I had to ditch all of the quick connect fitting because they either leaked or just didn't work, and the hoses became very stiff after several years. I'm guessing they were not ethanol friendly, and started leaking as the connector crimps became loose on the hose (hose shrunk). I regret not spending a little extra money and getting a good system. It might be ok for one-time use, but I wouldn't expect it to be a long-term investment.
Old 09-08-2024, 05:08 AM
