Picts of 73 Tangerine hotrod with twin plug 3.2
I can only say one thing.............WOW
Simply Stunning
![]() Returning Member after 10 year Absence |
Air Cooled
Very very tasty! Coil overs, dual fender coolers, 917 Zuff brakes, RSR front brace, integrated fire system. Very tasty indeed!
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
Reiver
THAT looks like a great time...like all of it.
De Oppresso Liber Strength and Honor 5th Legion |
Rescuer of old cars
Love the plate, and also the smooth rear deck lid. Fantastic!
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Love it
Uncertifiable!!!
Very, very nice! Beautifully executed.
Cheers, Johan
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
Beautiful.
Ole Skool - wouldn't have it any other way |
Fantastic. What are the specs on the transmission?
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
Wow. Do you know what that beauty weighs?
I can't find a single thing that I don't like (including the best licence plate I've seen). Did you build the car, or have a shop do the work? Curious to know the difference in handling and adjust-ability between the coil overs and the stock torsion bar suspension.
Perfect sports purpose build. I am so envious, and once again find myself regretting having ever sold my '72
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
Carmagic.us
Great car ! You should also share the light-weight key, that's what makes it complete. Looking at these pictures reminds me to get started on my 70 911T I have sitting.
Cheers Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems |
Consider adding 911R rear qtr windows....or not. Also maybe n a few years change the black graphics to match the white stripes....or not. So much fun.
Thanks for feedback on car. It's been a fun project. Klub Sport Racing did the majority of the work. I did whatever I could researched out all the parts and specs I wanted on the build. Klub sport did the heavy lifting.
The coil overs with helper springs in front make a huge difference in how the car rides and handles. IMO much better than the previous torsion bars. That helper spring really helps take out all the little harsh impacts that seem to unsettle the torsion bars, expansion joints and such. Car is set up for performance street and went with street friendly coil rates. Car weighs around 2200lbs with 5 gallons of fuel Here are some specs on the build. Transmission Aluminum 915. Rebuilt by Klub Sport Guard LSD Guard 2-4 short geared transmission Wevo gateshift Wevo bearing retainer plate Wevo transmission mounts Ring and Pinion 8:31 Gears: 1st OEM 11:35 Guard gears 2-5th 2nd 17:35 3rd 20:29 4th 24:28 5th 26:25 RSR 225mm lightweight flywheel Clutch: Centerforce sport lightweight dual friction Aluminum pressure plate Motor: Rebuilt by Klub Sport J&E Motorsports 10:1 3.0 to 3.2 conversion Forged Pistons and Mahle Cylinders with fire ring Webb Cam 7600rpm camshaft Carrillo Rods Wevo engine mounts Cylinder heads by Xtreme Cylinder heads. Custom ported, COMPETITION VALVE JOB, Race SPRINGS, TITANIUM RETAINERS, Beryllium valve seats, VALVE LOCKS & SEALS AND BRONZE VALVE GUIDES GT3 oil pump ARP headstuds JB twin plug distributer Twin MSD ignition SS engine hoses 46 PMO carbs High flow fuel pump Rennline RSR engine brace Zuffenhaus RSR brakes. 320mm Front Drilled Rotors. 930 Rear Drilled rotors. 23.8mm Master cylinder n-assist Suspension Wevo RARB roll bar consoles Front RSR Front Bushings Blistein steel body custom shock RSR coil over kit. Custom front shock insert. Digressive valving RSR adjustable bump steer kit Eibach 250 lb spring Eibach tender springs RSR replica front sway bar RSR semi-solid upper strut mounts Rear RSR 935 spring plate Blistein steel body custom shock. RSR coil over kit Eibach 350 lb springs. RSR welded in Rear shock tower reinforcements RSR replica rear sway bars Reproduction RS air bottle by Michael Eberhardt. Aged leather straps. ST classics leather door stays EB Motorsports (supplied by Rothsport) Fiberglass engine shroud and tinwear. Electric speedometer conversion 10k Tach 200mph Speedo Long wheel studs. Refinished hubs with repacked bearings. Basket weave material for Door panels and dash strip. Remove heater controls. Blower motor delete. Rennline block off plates Custom rolled front wheel arch lip, Trimmed rear arch lip. Undercoating stripped from Engine compartment. Oil tank customized with wide mouth filler neck and aluminum Blau oversized oil cap Elephant Racing brass finned external oil lines Dual Carrera widemouth oil coolers Elephant racing yellow Zinc through trunk hardlines. Custom RSR softline jumper lines from carrera coolers to hardlines. Tangerine: 2323 paint code: 018 (original color) with 356 ivory striped hood and engine cover. RS rear steel flares Original floor pans with original paint 100L vintage correct fuel tank (fabricated by Mash Motors) with custom center fill and dog-bowl (fabricated and installed by Klub Sport) 100mm aircraft style gas cap with 5 hole fin Full size Fuchs spare tire with R style tie down. Right fender fill welded off (Klub Sport) Original steel front bumper custom slotted for oil cooler RSR welded in Strut brace with Stainless Steel rod (Klub Sport) 911R style expanded metal grills custom fit to Horn Grills, Slotted front bumper, Fog light cutouts and Rear decklid engine cover. (Fabricated by Klub Sport) Rennline blower cover and smugglers cover, black anodized. Bosch H4 headlights LED exterior bulbs for brake, turn signal and all running lights. RS style front/rear turn signal lens GT racing RS style fiberglass rear bumper Front hood and rear engine lid rubber R style tie down straps Orange bar front Porsche crest Fuchs wheels refinished by Harvey Weidman: 15X7 and 15X8in Toyo RA1 205/50-ZR15 front and 225/50-ZR15 rear. ST style seats based on Scheel fiberglass shells with wide wale corduroy and brass grommets. Seat back gel coated with brass grommets. Custom drop seat rails. Tilting headrests (fabricated by TRE motorsports) REPA style 5 point belts with vintage correct REPA and Porsche patches ST style roll bar Halon fire extinguisher in matt black powercoat and billet head with rollbar mount (Safecraft) RS 380MM thick grip steering wheel with hockey puck horn button (Zuffenhaus) 911RS style rubber floor mats 917 Gas Pedal (D Zug) Brake and clutch pedal in anodized finish with custom brass spacers on clutch Rennline floorboards with RSR rubber pads added Black headliner RS lightweight Perlon carpet (no insulation) RS style light weight door panels RSR style dead pedal Heuer clock LED gauge bulbs Porsche radio delete plate Brushed aluminum gauge bezel rings SWB chrome rear view mirror 917 style drilled key Dyno is at the wheels. So with 16% drivetrain loss approx 305-310 HP and 260 ft/lb torque at wheels.
Oh my giddy aunt.
That is quite an extraordinary build sheet. And I bet that's not half of it. I hope you thrash it regularly...that suspension and engine demand it. I bet it makes your palms sweat even when popping down to the garage. P.S. Please post more pictures of the detail. This is the one place where it is okay to overshare. |
Wonderful build, thanks for sharing! Usually I can look at a custom build and find things I would change if it were mine, but this is perfect! Enjoy!
Wow just wow! I agree with so many above- there isn't a single thing I don't like about the car- looks like an amazing build!
Love it. Remind me of a narrow body version of the red magnus walker str with the white stripes. It was my favorite car he did. This s one appears no less impressive.
Fantastic build, so very envious.
Any chance we can get you to post a video at the track? I bet she sounds gorgeous, too.
