Pistons/Cylinders 71 911t 2.2l
Hi everyone, I've almost completed the teardown on my 71t motor and one the pistons is frozen inside the cylinder. Likely rusted to the inside of the cylinder due to the 30 years of inactivity. Anyways, I found a set of p/c's on ebay for around 1400, they are JE forged pistons and aluminum cylinders. I was wondering if anyone has used these p/c's and what they thought of them?
Porsche 911 84mm Je Piston Cylinder Kit 2 2 2 4 | eBay
Thanks,
Sebastian Roher
1971 911T Irish Green Coupe
Old 02-18-2015, 08:22 PM
Sebastian, when I had the machine work done for my 71T, I was advised to stay away from the AA cylinders. I ended up boring the iron T cylinders to 85 mm and installing JE 9.5:1 pistons. Used iron cylinders are readily available.
dho
Old 02-19-2015, 06:03 PM
dho
What was the reason they gave for steering clear of those cylinders?
Old 02-19-2015, 07:49 PM
Inconsistent quality.
dho
Old 02-20-2015, 07:44 PM
dho
What set did you end up going with? I think I'm going to go with JE for the high compression pistons but I'm unsure on my cylinder choice.. Everything is so damn expensive..
Old 03-03-2015, 01:07 PM
Sebastian, I used the original T iron cylinders, bored out to 85 mm. They are readily available used. I replaced the pistons with JE 9.5:1 pistons.
dho
Old 03-03-2015, 05:50 PM
mcaterino's Avatar
I did exactly what doswald did. Runs great.
Mike
Michael Caterino
Clemson, SC
1970 tangerine (=Tiger Orange) 'T' targa
restoration: mk911.blogspot.com
Old 03-03-2015, 06:06 PM
Straight shooter
Lapkritis's Avatar
Any luck the removing the offending cylinder/piston? If the engine is on a stand, I would suggest rotating so the cylinder is on top and then soaking from above with pb blaster. Use a brush to clear any debris from the two of piston/cylinder to let the PB work. If you're in no rush, let it set as long as needed. I prefer to use wood blocks for driving softer metal. I've seen frozen engines clean up surprisingly well once freed and honed. There's an outside chance you'll get lucky still.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-03-2015, 08:51 PM
Alas, she was stuck REALLY good and the shop cut the cylinder... We tried mystery oil, kroil, etc. Let it sit, but NOTHING.. I believe there is a picture on my thread of the cut cylinder? If not, it may be on my build thread I have on earlyS... Any leads on 90mm cyl?
R,
Sebastian
Old 03-03-2015, 09:22 PM
1971 911t
Old 03-03-2015, 09:25 PM
Straight shooter
Lapkritis's Avatar
Ah, tough break there.
You might try the classifieds here on Pelican for a single cylinder/piston. There are a lot of folks here with piles of spare parts.
Best of luck,
Andrew
Old 03-04-2015, 07:59 AM
Can these cylinders be bored out to accept a 90mm piston? I'm trying to do a 2.5 spec race motor
Old 03-04-2015, 12:10 PM
tharbert's Avatar
You have, if original, 84mm P/C's. You can go up to 86mm without machining the spigots. From what I understand, if you don' t have a 7R case, don't other. Talk to Henry at Supertec about P/C options. I found new Mahles too expensive and good used is very hard to find now. Henry had some palatable alternatives.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 03-04-2015, 12:55 PM
tharbert's Avatar
BTW, I'm building a 2.5 with a 70.4mm throw crank and 86mm p/c's...
72 911T 2.4 MFI
Old 03-04-2015, 12:57 PM
What kind of gas do you run with the 9.5 compression pistons? Any issues with the lower octane fuels? If you run zeniths, did you change the jetting?
Thanks,
Dennis
Old 03-04-2015, 03:03 PM
Tharbert, I am planning on doing 90mm so I'm sending the case out to Ollies to get the spigots machined. Probably going to get the case shuffle pinned as well.. I have a laundry list for them so that's where most of my budget is going. New pistons and cylinders are like 4600 (Nickies+JE pistons) that is EXTREMELY expensive (currently out of the reach of a mere mortal such as myself) What are the options I can go as far as p/c's? Don't want to put Chinese crap in my engine. I'll contact Henry and see what he recommends. I may just get my cylinders bored but I have to purchase one as we had to cut a cylinder to get the piston out.
Old 03-04-2015, 06:15 PM
Thanks,
Dennis
Dennis, I hope we can get away with using high octane gas... I don't want to build a motor that can't run off of pump gas... Currently exploring options other than zeniths.. I've got a few leads on webers but everyone I come across are in the 2k range and by the time you do a rebuild, put in what you want, etc. PMO is looking like a viable option, but is quite expensive as well ($3400)... Time to take out a second mortgage?
Old 03-04-2015, 06:18 PM
