Targa_PB_78_SC
It is also curious about the big disparity in fade rates of the material. All the targa emblems I found for 78's are shinny not black. Mine faded quickly as it was shinny in 84 when I got it. I wonder if any of the 80's emblems faded ... humm ? |
I did find two tests of '78 targas, one in Car and the other in Motor, and they both had black trim. The photos aren't good enough to reproduce here, but you can see that all of the trim is definitely black. Most other tests from that era showed cars (coupes and targas) with bright trim, but there were a couple european tests of '78 coupes with black trim. I did find a picture of a mid-year targa with black trim. Best guess is that it was a '74 or '75, but it was a later photo (not taken in the time frame it was built) so I can't say it was original. Likely, though... Quote:
I think Porsche had some problems with their anodized pieces for a while. I've seen too many faded pieces from that time frame. Porsche bought those pieces from suppliers. There's nothing that says the same supplier supplied all of the different trim pieces. Plus, if you've ever fooled around with anodizing, it's hard to maintain a given color from batch to batch. I won't get into the technical reasons why, just take my word for it. Black is a color that is hard to do right. I've seen new pieces that are jet black, some that have a purple cast to them. Quote:
I never had a a '78 targa, but I did buy an '80, back in the day. I have a picture of it, taken in the winter of 1982, shortly after I received my '83 coupe. It's not a big photo, but you can already see that the targa badge is a couple shades lighter than the roll hoop. Hope this helps, JR Last edited by javadog; 08-13-2015 at 08:03 AM.. |
Maybe this will help. In this photo, from the top down, you have:
NOS bright windshield trim 44-year old bright windshield trim faded black anodized coupe quarter window trim The quarter window trim on a coupe is partially covered by a rubber gasket. You can see the part that was exposed to weathering is almost completely free of the black color. The part that was under the rubber gasket is black, and has a little film of dirt. The very bottom edge, that went over the pinch weld, is completely black. The underside is black, with a little dirt. It's hard to tell from the photo (i-phone) but the NOS bright trim is a little brighter than the 44-year old bright trim, which is a few shades brighter then the faded portion of the black trim. JR
If you want to wade into the subject of anodizing, how it's done, what can go wrong, etc. you can visit a forum that deals with industrial metal finishing. A couple to get you started:
Black anodized parts fading - Non-UV cause Fade Resistance of Color Anodized Aluminum Most fading is probably from UV exposure but it can occur from temperature, how the parts were processed (sealed or not, prep work done prior to anodizing, etc.) and a host of other things. Note that different dyes have different fade resistance, even within the same color family. Worldwide, there are probably hundreds, if not thousands, of dyes available. JR Last edited by javadog; 08-13-2015 at 10:35 AM.. Reason: sp. |
Targa_PB_78_SC
Interesting so if in 1978 the targa bar was always black what is this one?
seems to be a 1978 SC targa without a black targa bar 1978 Porsche 911 SC Archived Road Test – Review – Car and Driver |
Targa_PB_78_SC
Targa_PB_78_SC
My guess is that's an early production car from the press pool at VWOA. I've seen several early cars, usually photographed for brochures or something similar, that also had brushed stainless targa bars. Maybe it was optional, for a while. I think there's another one in this thread. No doubt some of them got built.
That said, I've seen errors in the brochures. If you look at enough of them, you'll find ROW cars in US brochures, or cars that were actually from the previous year, etc. If you look carefully at Porsche's publicity photo showing the finished production of 20 911SC/RS models, for homologation purposes, you'll notice one they stuck way in the back that's just a standard white 911... All I can tell you is that there's no option code for it in the parts database, no part number for a brushed stainless targa bar, etc. No doubt some of them got built. Part of me wants to say that in 1978, bright trim was standard on the coupes, and black was optional; and on targas, it was the reverse. In any event, when you got black trim, it was all black and when you got bright trim, it was all bright. I've never seen a half black, half bright car. Notice the black targa and 911SC badges in the C&D article. JR |
JR |
Try this:
http://forums.pelicanparts.com/porsche-cars-sale/805397-1978-porsche-911sc-targa-3-0-a.html Or this one: http://www.schmitt.com/viewimage.asp?ID=4931 Or this one: http://dealerrevs.com/gallery/52800048.html Last edited by javadog; 08-13-2015 at 12:37 PM.. |
I want to believe that my '78 Targa came in the current aluminum type finish in part because I think it looks good against my metallic silver paint. It is also consistent in color and shade.
However.....I just went out to the garage and was able to slide the short "coupler" piece that connects the windshield trim (on both front and Targa glass). After sliding the coupler a quarter of an inch I can see the trim is clearly black under the coupler. Although much less pronounced, I do also see a hint of black in the spaces around/inside the "S" on my 911SC emblem on the rear lid. My car is definitely still in project stage, but when I repaint it in original metallic silver in a year or two, I will now have to consider "restoring" all the aluminum finish trim back to black. I'm still a bit confused but I must admit.....JR, you may just be right after all. Kerry
1978 911 SC Targa 2007 Boxster (sold) Last edited by KerryM; 08-13-2015 at 02:13 PM.. |
Targa_PB_78_SC
Good to know for sure what is correct for originality. Changing the rear window trim may never happen for me. Thanks Kerry and JR for helping me find the true as built. Hope I can remember this
So after all the discussion, what is the best way to return the trim to black?
1978 911 SC Targa 2007 Boxster (sold) |
If you want it original, have it anodized again. Not cheap.
Most people just paint it all. JR |
