1986911's Avatar
Found this on my engine oil drain plug?
How concerned should I be?
I found this changing the oil over the weekend. There was more "fuzz" than usual on the magnetic drain plug and these two pieces were stuck on it.
Car is low mile 45k 1986 911 3.2 and unfortunately seldom driven. Aside from valve adjustments, no engine work ever. It sat for around 2 months before I went for a drive to warm up the oil prior to changing it. No strange noises coming from engine.
I plan to cut the oil filter tonight.
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 03-04-2015, 06:56 AM
I'm assuming it's steel (not aluminum) if stuck to the plug?
'87 911 Carrera Coupe (go fast, small parts / small kids hauler)
'04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius")
Old 03-04-2015, 07:09 AM
That is not good news. It looks like a piece of a ring.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 03-04-2015, 07:14 AM
Strange. 1983 pennies were still mostly copper and would not be attracted to a magnet like the coated steel one of the last several years. Of course it could have settled there and obviously did.
tom
Old 03-04-2015, 07:17 AM
French Import
zippy_gg's Avatar
tom
Uh... the penny is just there to show the size of the couple of metal pieces found attached to the magnetic drain plug...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 03-04-2015, 07:21 AM
I'm thinking part of a ring too if steel.... has that flat thin profile.
Agreed that's in the "not good" category.
Old 03-04-2015, 07:25 AM
Zippy_qq says:
My bad. What's wrong with me??!! A penny is larger than the drain hole!!!
Tom
Old 03-04-2015, 07:30 AM
Hi
Targa Me's Avatar
I would do a compression test and leak down test to what those numbers are.
"A good sense of humor is the best thing to have in your toolbox when working on these cars."
Quote by Charles Freeborn, Pelican.
Old 03-04-2015, 07:31 AM
douglas bray's Avatar
Rings can not escape their grove without carnage to the piston. Don't think its a ring.
Old 03-04-2015, 07:41 AM
French Import
zippy_gg's Avatar
If there was a lot of fuzz on the magnet of the drain plug in addition to these small pieces I would suspect a failed bearing.
Do you have a picture of the drain plug with all the fuzz on it?
Gilles & Kathy
Old 03-04-2015, 07:47 AM
T77911S's Avatar
the 2 post above ^^^but it sure looks like part of a ring.
dist drive gear?
perhaps more pics and closer up.
is it flat? teeth from a gear would have a tapper to them
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-04-2015, 07:51 AM
Derek911's Avatar
I didn't realize there was copper components in the engine, but what is really remarkable is that it looks like a real penny. This is like the woman in Florida that found the face of Jesus in her toast.
Old 03-04-2015, 08:09 AM
Taking it apart is easy
Jerome74911S's Avatar
If you are able to take a real 'macro' photo that would help. And, on a plain white background.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 03-04-2015, 08:15 AM
joe payne's Avatar
Just drive it. It's too late now. If the car seems fine the hell with it..
jtp911
Old 03-04-2015, 08:20 AM
db_cooper's Avatar
Would not be a ring..there would be big chunks of piston in the oil. Not likely anything from the timing chest..and if it is steel..there should be some big time collateral debris in the engine oil.
Someone may have dropped some junk inside the valve cover when the valve adjustment was done.
Most shops have a parts cleaner that is used for cleaning everything..and they do get old engine debris in them..and if you are not paying attention while you are washing your 911 valve cover..the old metal bits get brushed up inside the valve cover.
I used to find some interesting things on the old 911 engine oil sump plates..sockets, nuts, washers..feeler gauges, etc. With the 3.2 drain plug..no sump plate to collect and inspect bits dropped inside the engine.
Old 03-04-2015, 08:24 AM
^^^ I would be very reluctant to agree with this. There are plenty of places for additional pieces of shrapnel to hide in an engine, and every one of them is itching to get loose and do additional damage.
Jerome
Old 03-04-2015, 08:25 AM
Derek911's Avatar
Do what most people do. Drive it until you get more symptoms or sell it and play dumb. Nothing against your car, but this is one reason why I don't overvalue low mileage cars. These cars need to be driven, and 45,000 miles in almost 30 years is crazy. People pay a premium for low mileage but they are the one stuck with all the problems that haven't popped up yet. Things get stuck and frozen and oils dries, seals get dry, when sitting, then you crank it up and things break or leak.
Old 03-04-2015, 08:36 AM
joe payne's Avatar
Do a complete re-build of the motor @ an average cost of $10,000. That's the other choice.
jtp911
Old 03-04-2015, 09:55 AM
Hi
Targa Me's Avatar
[QUOTE=Derek911;8515101]Do what most people do. Drive it until you get more symptoms or sell it and play dumb. Nothing against your car, but this is one reason why I don't overvalue low mileage cars. These cars need to be driven, and 45,000 miles in almost 30 years is crazy. People pay a premium for low mileage but they are the one stuck with all the problems that haven't popped up yet. Things get stuck and frozen and oils dries, seals get dry, when sitting, then you crank it up and things break or leak.[/QUOTE]
Interesting note: When I bought my 3.2 it had 95k miles on it. Which at the time equates to the car being driven about 4500 miles per year. When I took ownership the engine had 4 oil leaks. Before buying any new gaskets or seals, I drove the car every day putting about 150 miles on it, per day. Long story-short, 3 of the 4 leaks sealed up and 1 I needed to take care of.
Bottom line, these cars are meant to be driven.
Going back to the original issue, do the compression check and leak down as stated earlier. Maybe put on a couple thousand miles on it and recheck the drain plug magnet again.
Old 03-04-2015, 10:15 AM
broken piece of feeler gauge. Mic it...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-04-2015, 10:16 AM
