Washed car... Now won't start!?!
'87 carrera. Runs great, drive it every day. Drove home, parked in driveway, grabbed a beer, gave it a quick scrub- then when I went to crank it to put it back in the garage, it turns over, but won't catch, not even a little- this has never happened before- I'm guessing water got so where it shouldn't... Help?
French Import
Open the engine lid and dry all the water you can see with compressed air and dry rags, especially at the coil and spark plug leads...
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Water in the dist cap or coil.
It will probably start on its own within a day
1986 Bosch Icon Wipers coupe. |
Thanks for the replies. I left the deckled propped open all night, and it fired right up this AM. Water got in there somewhere, just couldn't figure out where. I'm guessing distributor cap?.
Pull the cap and examine it. I was having terrible wet-start issues, turned out that there was a 1/4 inch hole blown in the side of the dizzy cap nearest to the engine block (so, hidden away). Obvious problems ensued
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Wipe inside of dizzy cap and spray w/ WD40.
UFLYICU
What kind of wires do you have? There was a thread a hundred years ago about Clewett wires that were wicking water into the plug ends.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
