Smoky Mountain Region PCA
A/C Condenser Baffle Plastic Rivet
At long last, I'm finally getting to reassemble my engine lid and Carrera tail on my '82 911 SC. There are two rectangular baffles with foam strips (one on each end of the A/C condenser under the engine lid) that were each attached with a bolt on one end and a plastic rivet on the other end. Which end of the baffle does the plastic rivet go in - the hole nearest the top edge of the engine lid or the other hole?
Thanks, John |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
![]() ^^^^^ Does this help? Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
I think what I'm calling a baffle is part #9 "cover plate," but the diagram doesn't show the cover plate fasteners - my '82 had one plastic rivet and one bolt holding each cover plate ... I'm "assuming" that's correct and original? ... but my question is which fastener goes where!
Thanks, John |
John,
The 2 side baffle plates, 911-573-027-00, are held into the deck lid using 6mmx10mm allen's with wave washer on the compartment side and a hex nut on the outside deck lid side. ![]() Porsche 911-930 Air Conditioning Upgrades |
By the way, my Kuehl A/C works GREAT! ![]() Thanks and regards, John |
John,
Glad to hear you are satisfied with your Kuehl AC system. For the hardware, use 6 mm steel Best regards, Griff |
| Tags |
| a/c , baffle , plastic , rivet |
