gear ratios
Bit of a noob question here, but in my 78 911, the 4th and 5th gear are exceptionally close in gearing. Perhaps 500 rpm different at speed.
Is this normal, sort of an overdriveish type of thing, or have my hears been modified for more track use type of thing?
Old 06-20-2015, 04:26 AM
Your owners manual has a gear chart in it that will give you road speed vs. rpm in each gear.
JR
Old 06-20-2015, 04:36 AM
gearhead
That doesn't sound right. If you give us approximate rpms at the same speed in the two different gears it will be pretty easy to calculate which one is not stock and roughly what ratio it might be.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-20-2015, 10:12 AM
