New led driving lights
I am experimenting with some new LED driving lights.
these have 9 Cree high intensity bulbs in a 5" diameter housing. they mount nicely on the splitter on my 911 RS Tribute.
The purists will scream, but I do drive this car all the time and I love having the best lighting.
And I want good DRL for driving on the narrow mountain roads during the day.
They draw only 2 amps each so they are pretty efficient, and the LED bulbs will out live me!
Here are the specs
Led Power: 27W
Body Color: Black
LED type: Cree
Dimensions: 5 inch
Waterproof rate: IP 67
Operating Voltage: 10-30V
Beam Type: SPOT
Lumens Output: 1800 LM
LED quantity: 9PCS*3W high intensity Leds
Color Temp: 6000K
Here is a detail shot of the lights each puts out 1800 lumens
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 08-01-2015, 08:21 PM
My other ride is a C-130J
RNajarian's Avatar
Wow neat project
I wonder if they could be direct replacement for existing fog lights
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 08-01-2015, 09:02 PM
Cairo94507's Avatar
I believe those will fit the stock early 914 fog light grills. I looked at them for my Six, but they are just to "new" looking to fit the stock appearance of the car. However, they appear to be nice and bright and were cheap at about $28 each, assuming these are the same, and they appear to be. Yeah, I know a 914 isn't a 911..... I have a 911 too.
'71 914-6 #0372
'17 Macan GTS
Old 08-02-2015, 06:05 AM
El Duderino
tirwin's Avatar
I like the look. Nothing wrong with experimenting.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-02-2015, 06:30 AM
Thanks tirwin! They are super bright and surpisingly wide beam. So far so good.
They are very bright in daylight which is what I want for DRL use.
The housing is finned cast aluminum. I am thinking of making some aluminum mounting brackets and anodizing them. I think it would be better than the chrome.
Here are some better daylight photos.
03 Boxster
Old 08-02-2015, 10:01 AM
wwest's Avatar
Those can't be driving lights, more like a flood, or fogs, lots of up close wide area lighting. No aid in night time distance vision like what driving lights are designed for.
Cooling the LEDs is the most critical design aspect for lighting of this type.
The reason early DRLs used high beam bulbs at low voltage was to be visible at distances beyond what the low beam, or fog light, pattern provided and yet not "blindingly" BRIGHT.
Old 08-02-2015, 10:24 AM
WWEST and do you have ANY practical experience with these lights?
By the way, I want them to be "blindingly" BRIGHT as DRL lights!!! I don't want them to be polite!! I need all the help I can get on these mountain roads in the daytime.
I am surprised you commented, this has nothing to do with A/C!!!
03 Boxster
Old 08-02-2015, 10:34 AM
The housing is heavy cast aluminum. I feel they have designed for cooling well.
03 Boxster
Old 08-02-2015, 11:46 AM
wwest's Avatar
My LS400 has 2 "high" beam bulbs on each side. One is a high/low and the other is a single filament used as low voltage DRL and high beam pattern "fill".
I replaced the DRL with a compatible socket LED with what I thought was an adequate heat sink. The bulbs included a feature that resulted in powering off entirely if the LED approached an over heat level.
So I found one's with an improved heat sink and the "feature". No more shut off on "hot" days.
My 2001 C4 come with a small 5W "city light" in each side that I converted to a LED with a "distance" mirrored reflector.
Politeness resulted in my adding a resistor to reduce the brightness in DRL mode.
Since I suspect the LED lights in question do not have anything close to a normal high beam pattern, more like fogs, I doubt if you have a need to be polite.
Old 08-02-2015, 11:52 AM
