Solved exhaust drone on 2 in / 2 out B&B
I have an 86 Targa with B&B headers with heat and a 2 in / 2 out muffler. The Billy Boat muffler was too loud and had a bad drone. I replaced the muffler with a MagnaFlow muffler. I picked up a bit of low end torque with this muffler. Overall volume came down. Great sound above 3K. However the drone between 2k and 3k could make your head split. I just installed a Dynatech Vortex into the driver's side outlet. Overall volume might be down a tiny bit but THE DRONE IS GONE! It now sounds great at all rpms.
This should work for all 2 / 2 muffler systems. Better than capping one outlet. |
2-3000 rpm exhaust drone
Thank you for this drone update.
I LOVE the sound of my B&B header and exhaust system, but the drone can become wearisome after a while. Its just - they sound so sweet when the motor is really working and it really opened up the motor's performance!! Anyway, I have a cap for one end of the exhaust outlet, but it does drop the power noticeably and so I typically dont like using it. Im glad to hear of an alternative. Thanks for posting. Allan. |
Cheers, Jt -84 911 targa |
I will google but do you have a link? It looks like they only go down to 3" diameter. Did you find a smaller one.
I just noticed you are local, I might try to come by and sample at some point if you are up for it.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. Last edited by Elombard; 08-03-2015 at 11:41 AM.. |
Send me a PM on where in Atlanta you are. |
Also if you need a smaller diameter you can try the Car Chemistry C C insert. Exhaust - CC Inserts - Car Chemistry, Inc.
I have read good things about them. |
Brew Master
I fixed it for my brother by simply blocking off one of the outlets. It was amazing how much difference it made.
Bill,
The dual large outlet muffler is the one I have & yes it does drone between 2200-2900rpm. I guess I will try this solution and see what it does. My question or hesitation is: I dont know if slowing exhaust flow out of one outlet on the muffler will create back pressure issues on one bank of the cylinders and not on another - thereby unevenly stressing the motor?? I suppose this wont be an issue if the exhaust gasses are mixed inside the muffler, but I cant see that without cutting it open, and I dont want to do that. |
