964 battery issues
My battery constantly goes dead I put a slow trickle charger on it sine I drive it very little Today after disconnecting the charger it would not start A weak cranking occurred so I humped started it and drove it for over 100 miles When I turned it off and attempted to resart Too weak to restart again Battery is only 1yr old What should I be looking for as a problem
Old 09-20-2015, 02:41 PM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
alternator not charging.
Use a multimeter on the battery with the car idling you should be getting 13v+, if not you probably have a bad voltage regulator on the backside of the alternator.
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 09-20-2015, 02:58 PM
Bandwidth AbUser
Jim Richards's Avatar
The 964 climate control unit (CCU) has a transistor that tends to fail, leading to a small fan on the unit to keep running after the car is turned off. Actually, it's supposed to run from some number of minutes after the car shuts off, but the transistor failing lets it run continuously. This is one of the limited number of electric bugs that run down the battery on 964s. I used a DC clamp on ammeter from Sears to verify that the CCU was the source of my battery drain. When I pulled the fuse that powered it, the current dropped to a negligible amount. I looked on Rennlist for the thread about repairing the CCU, and bought a new transistor, soldered it in, and verified that the CCU no longer caused a significant drain on my battery, I hope this helps. Good hunting!
Jim R.
Old 09-20-2015, 04:40 PM
Since I drove the car over 100 miles after jump starting and then it still wouldn't start it sounds like the voltage regulator could be the issue
Old 09-20-2015, 05:48 PM
964TargaC2's Avatar
My parasitic drain turned out to be drivers door light switch, if it isnt working power window system stays energized and drains battery, If working when you open door the power window system is shut off
It can be intermittent but easy to check, if you shut off car and open door and windows work its more than likely the switch
I think that maybe I'm dreaming..
Old 09-20-2015, 06:11 PM
MrScott's Avatar
+1 on multimeter. My guess is parasitic drain has discharged your battery one too many times and now it won't take a charge. You should get some compensation from the warranty/exchange.
1980 911SC
Old 09-20-2015, 06:20 PM
I have the same issue with CCU fan running continiously and battery running down. However, if I pull fuse and then replace it, the fan stops running. Is this a bad transistor or something else?
Old 05-06-2016, 06:55 PM
always suspect the battery first. Have it load tested to see if it is holding charge. Does not matter if it is a year old. Batteries are a very weak link in the system.
You have to eliminate the battery as a possible cause first before you start throwing parts at ti.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 05-06-2016, 07:48 PM
