Mark
1979 911SC Targa |
I have found my official Porsche GMBH workshop manual for the original 1977 911S and it looks on its circuit diagram (helpfully in black and white), as if it is the same as Timmy posted above, so requiring a five pole relay for the fuel pump. I have found what I think is a 5 pole SS relay from a competition parts seller in the UK at the Brands Hatch Circuit. However, it is only 17A and for starting overload current flow, I would have preferred 25A. I am waiting for confirmation that it is a non-latching changeover relay and not just a 5 pole with one pole not connected. Strangely if I wanted a latching SS 25A 12V relay, they are easy to find.
Wilson |
El Duderino
I believe the purpose of the diode is to act as a "flyback diode". It is the presence of this diode that makes the red relay different from the black ones. Porsche engineers believed it needed to be there. I would not omit it.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
El Duderino
Here is an interesting article on flyback diodes.
https://electronics.stackexchange.com/questions/56322/do-i-need-a-flyback-diode-with-an-automotive-relay
If I replace the relay with a solid state one, there should not be any requirement for a diode as there is no arc burn on a solid state relay, so no spike to affect the ECU/DEM. My 911 has a rev limiter but it feels like ignition to me but I suppose might be fuel. It cuts in just above my 7200 RPM red line.
Wilson |
back EMF from the collapse of the de-energizing relay coil. It's meant to protect the solid state over rev protection ckt. Therefore, you are correct in that a diode would probably not be necessary as there is no relay coil with a SS relay.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 10-27-2018 at 09:40 AM.. |
El Duderino
Ok, I see what you are doing now. I initially thought you were just looking for a different supplier of the same type of relay. Interesting. Keep us posted on what you find.
I had a coil go bad the other day. It was 3, maybe 4 years old. The car had the original black Bosch coil for 30+ years until it died. They definitely do not make ‘em like they used to!
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! |
Wilson |
all i can add to this is..some of you should send this conversation to Porsche in Stuttgart so they know and tell their people in China how to make these relays reliable again;-)
just my 02 cents.... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged! Last edited by Dr J; 10-27-2018 at 05:56 PM.. |
San Diego, CA
Given that after 7 months, I am still waiting for a software update for my 2018 model Panamera, to correct instrumentation errors (speedometer does not change from MPH to KPH), which Porsche admit was their fault, I suspect getting them to repatriate production of relays for old cars is a non-starter. Wilson |
hi Wilson...that says it all ..btw i used to live near your Tourtour...do you know there lady, Sears??
I was in Bargemon.............. Ivan
ROW '78 911 Targa
Perhaps this one?
https://www.waytekwire.com/item/75532/InPower-VCM-10-Dual-Input-Solid-State-Relay-/ Never mind... http://www.inpowerdirect.com/docs/PDS-88C.pdf
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 10-28-2018 at 01:39 AM.. |
I don't know Lady Sears but if you lived in Bargemon, you must have come across the very pleasant and helpful Dutch estate agent, Theo Punt of France-Sud Immobilier in Bargemon. Wilson |
I fear neither of those are suitable. They are dual input and single pole control. What I need is a single input but dual pole changeover output i.e two input terminals and three output. These SS relays seem to be as rare as rocking horse poo in DC in/DC changeover and I am having difficulty tracking one down. If I wanted DC/AC they are easily available. I have now also received two genuine new, not Üro but Porsche red relays (albeit made in China). So I now have the one plugged in, that I know is a Üro as I found the box and two OEM spare ones. I also have the query in to Wehrle to ask if they might still have some original stock left that they could sell me. Wilson |
yup i know of him right at the corner in down town;-)
Heck, I’m only 5 not 71!
Pat Henry Targa80 1980SC Targa (Mocha Brown) |
It will be interesting as and when the Üro relay fails and I take it apart, to see if the diode has been omitted and that is what the problem is. I would not be totally surprised.
Wilson |
| Tags |
| failure , fuel pump , relay |
