Brap
tmaull's Avatar
Tach Clean Up
The tach in my car is very under damped, and needs a rebuild. I found another one on the classifieds and bought it as is. It needs a bit of work. The glass is a little scratched up and it has a big stain at the top. First, how do I get the glass out, and second, do you have any ideas about how to remove the stain, and perhaps polish the glass?
Picture here:
Thanks!
-Tom
1980 911SC Coupe 3.4
1995 Miata
2005 Tacoma
2009 Street Triple
Old 12-21-2015, 02:34 PM
Take your time with a small flat screw driver or other pointy tool and carefully pry back the black bezel with the gauge resting on its face.
Once you go all the way around the bezel should slide off and the glass will come out.
Really, take your time. Don't damage the bezel.
Once you're ready to put it back on just bend the metal back the opposite direction.
Whatever marks you put on the inside shouldn't show when the gauge is back in the car.
Old 12-21-2015, 02:42 PM
The gauge face is most probably plastic, being the reason why it's scratched up. I'm currently looking around for a new glass face for my tachometer. Does anyone know of a place that sells vdo gauge parts?
Old 12-21-2015, 02:53 PM
Brap
tmaull's Avatar
Chris, yeah you are right - plastic. Probably not the easiest to restore.
1995 Miata
2005 Tacoma
2009 Street Triple
Old 12-21-2015, 02:54 PM
MConn's Avatar
Our host sells them - 1987 Porsche 911 Carrera Coupe - Dashboard & Steering Column - Page 2
Mike
The more I learn, the less I know.
Old 12-21-2015, 03:10 PM
Novus plastic polish will make them look new again....I've used it on scale model paint and it works like a charm.
Old 12-21-2015, 04:02 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Hollywood Speedo, not cheap but will look like new, add a voltmeter and its a home run.
'84 Carrera
'75 911S
They did both of mine, above.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 12-21-2015, 07:41 PM
Brap
tmaull's Avatar
ClickClickBoom,
Those look great. That's probably what I'll have done to my current tach. It needs a rebuild already, and the voltmeter would be very useful. But I think in the mean time, I'll clean up the tach I bought on the classifieds and put that one in.
1995 Miata
2005 Tacoma
2009 Street Triple
Old 12-22-2015, 06:53 AM
