Upier's Avatar
Unusual 911 issue Any ideas?
I have a truly strange problem. The car is a 1986 911 Targa with LSD.
I was driving home from work. Cold day about 28 degrees. I drove about a mile. I shifted but it seemed like I missed the gear because it reved to 3000 rpm but wasnt driving the wheels. Clutch pedal felt normal. I stopped. I could shift into any gear without using the clutch but no drive. No noises. I got flatbeded to my garage. Lifted car. With rear wheels in the air I can turn one and the other one turns. I checked the CV joints and they are okay. I had a torn boot on one but no damage. Now the really weird part. I stared the car and but it in gear. Wheels turned. I lowered the car and was able to (before replacing boot) drive the car out of the garage and turn it around and then back in. So it worked in 1st gear and reverse.
So what could be wrong with it?
Old 01-30-2016, 08:01 AM
Sorry - I'm confused. You can shift into 1st and reverse and move the car. How about the other gears?
Old 01-30-2016, 09:13 AM
Upier's Avatar
I only tried those two gears because I didn't want to get stranded. Before I couldn't get it to move in any gear.
Old 01-30-2016, 01:00 PM
Rescuer of old cars
Arne2's Avatar
Shift coupler and linkage bushings are an obvious possibility.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 01-30-2016, 01:13 PM
Originally Posted by arne2 View Post
shift coupler and linkage bushings are an obvious possibility.
"But instinct is something which transcends Knowledge
We have undoubtedly certain finer fibres that enable us to perceive truths when logical deduction or any other wilful effort of the brain is futile"
Nikola Tesla
Old 01-30-2016, 03:05 PM
Upier's Avatar
How could this fix itself?
Old 02-01-2016, 07:10 AM
It doesn't. Some call it "mystery shift" where you think it goes into the gear you select but because of the worn coupler and bushings it is hit or miss.
1984 Carrera Targa
Old 02-01-2016, 07:52 AM
patz's Avatar
CVs, if no move at all.
Old 02-01-2016, 08:07 AM
Bulldog9's Avatar
Are you saying that you can shift into any gear with the car running and not use the clutch? If that's the case, you likely aren't putting the car in gear, just moving the shifter. Is likely the coupler. Pull the cover off and I bet you'll find the coupler is disconnected from the trans gear shaft.
1976 Porsche 912E http://www.912bbs.org/vb/showthread.php?43391-770-Update
1989 Porsche 944 S2
2020 Mustang Bullitt
Buncha Moto Guzzi Motorcycles
Old 02-01-2016, 08:17 AM
Upier's Avatar
That was the problem but later was able to get into gear and move the car.
Old 02-01-2016, 08:55 AM
wwest's Avatar
Clutch remained disengaged..... COLD?
Old 02-01-2016, 09:01 AM
Upier's Avatar
Yes it was cold. About 25 degrees. Only drove one mile before the issue.
Old 02-01-2016, 06:40 PM
Air Medal or two
afterburn 549's Avatar
Your pedal cluster sucks .
Rebuild with bronze bushings, install a couple grease zerts
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between.
Old 02-01-2016, 08:53 PM
Bulldog9's Avatar
You need to give more details. Does it change gears normally now?
BLUFF, clutches dont stick open(disengaged), they stick closed (engaged). You have shift linkage problems, an easy fix if it is the coupler or shifter itself, BAD if it is internal to the trans (unlikely) . Take off the access panel and check the bushing and connection between coupler and trans.
1989 Porsche 944 S2
Old 02-01-2016, 09:04 PM
