Beaky's Avatar
Dash lights & Switch
My interior dash lights (these are LED’s) have recently started to annoyingly constantly flicker.
First it was just the one bulb now several are doing it, by adjusting the dimmer setting they stop for a while then start flickering again.
Now I assume it’s the 30 year old dimmer circuitry that’s now malfunctioning and a new switch is in order.
As I always have all my cars dash lights set to maximum, I don’t care for or need the dimmer option.
Is there just a simply Porsche "on off" replacement switch that can be purchased or do I need to decommission the dimmer function on a new or on the old switch for that matter or can the dimmer element be by passed?
Regards
Cheers Beaky
Old 02-07-2016, 03:34 PM
Interesting - the "dimmer" is just a variable resistor in the switch.
Is the flickering "constant" (meaning equal time on/off) or "intermittent" (meaning there is no discernible pattern to the flicker)?
Old 02-07-2016, 03:42 PM
Member 911 Anonymous
DRACO A5OG's Avatar
You could remove the switch, marking all the wires and inspect the rheostat. But before that I would check all the grounds to insure they nice and free from corrosion. If you have not do so, I would install a inline fuse as the black/blue wire is not fused.
'85 Carrera Targa
PCA/POC
Old 02-07-2016, 03:51 PM
muck-raker
kidrock's Avatar
try dousing the rheostat dimmer switch with electrical contact spray before doing anything else...it's probably just dirty.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-07-2016, 04:23 PM
ROW '78 911 Targa
timmy2's Avatar
If you want to bypass the rheostat just move the black/blue wire over to the grey wire terminal for the running lamps. You can look up the terminal number for your year to confirm. Fusing is always a good idea.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 02-07-2016, 04:25 PM
Beaky's Avatar
A bit of both but more than often its a constant flickering,
Cheers Beaky
Old 02-08-2016, 12:09 AM
Beaky's Avatar
I have already installed the fuse, will check the earthing this evening
Cheers Beaky
Old 02-08-2016, 12:10 AM
Beaky's Avatar
In terms of a by pass I believe my wiring is a follows:
N - Grey/White
58l - 2 x Grey/Black
58r - 2 x Grey/Red
75 - 2 x Red/White
57 - White/Green
58a - Red in line fuse and then to the Blue/Black from the loom
58 - 2 x Grey
56 - White/Black
So move 58a to 58, what do I do with the grey wire just tape that up?
Cheers Beaky
Old 02-08-2016, 12:40 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Light switch.
For our '86.
Hope this helps.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 02-08-2016, 01:03 AM
ROW '78 911 Targa
timmy2's Avatar
Should have a female spade with a male tab available on your wire. If not install one. Then just double it up keeping the license lamps in the circuit as well.
Dennis
Old 02-08-2016, 02:05 AM
Beaky's Avatar
So has anyone tried this before (moving 58a to 58), does this work, and is there any issue about load on terminal 58?
Just a little concerned as I don't want to end up with fried wiring!
Cheers Beaky
Old 02-08-2016, 09:42 AM
ROW '78 911 Targa
timmy2's Avatar
Led lamp load is what?
Current load on that cicuit now is 2 incandescent lamps.
Pretty negligible added together...
The load of the dash lights is already going through the switch, just on a different contact.
Your only other alternative is repair or replace the switch.
Pop a couple of led lamps in the license plate holders and you'll be fine...
Dennis
Old 02-08-2016, 10:08 AM
famoroso's Avatar
Where? Spray in / above the exposed piece of fluted metal between terminals 58r and 75?
Suggestions, or link, for quality LED license plate bulbs?
Old 02-08-2016, 04:44 PM
Beaky's Avatar
Will report back on Saturday once I have moved the wires
Thanks in advance
Cheers Beaky
Old 02-09-2016, 01:35 PM
Beaky's Avatar
So did this and still had some flickering, so can only assume its a dodgy connection or a faulty relay (if this is one!)
Cheers Beaky
Old 02-13-2016, 02:57 AM
ROW '78 911 Targa
timmy2's Avatar
Did the cleaning or moved the source wire?
If still flickering I am thinking it may be a ground issue.
Dennis
Old 02-13-2016, 11:56 AM
Are you sure the LEDs are dimmable? Many aren't.
Old 02-13-2016, 12:04 PM
Beaky's Avatar
The moved wire, still need to clean the connections/grounding
Cheers Beaky
Old 02-13-2016, 12:32 PM
Beaky's Avatar
They have been working fine for several years, only stared flicking a few months ago,
Thinking about it I noticed the flicking after the car was laid up in the garage for a few weeks
Cheers Beaky
Old 02-13-2016, 12:34 PM
wwest's Avatar
Fairly common LED failure mode.
Old 02-13-2016, 12:47 PM
