hilandscott's Avatar
Exclamation oil lines/reservoir after thrown bearing
As I am now faced with prepping the car as best I can to insure that another terminal failure does not result, what are the best cleanup methods for getting metal debris out of the solid lines and oil reservoir. I have heard suggestions ranging from soapy water and the garden hose to taking to a radiator shop and getting steam/air pressure run through the parts. I'd like to know how this cleanup is done best.
Thanks!
John
'78 911 SC 3.0
Old 10-08-2001, 06:37 PM
Question
Searched the archives again and couldn't find any cleaning tips -- yet I am sure someone has had to deal with cleaning things up after a terminal engine failure...
'78 911 SC 3.0
Old 10-09-2001, 06:44 PM
Senior Member
Doug Zielke's Avatar
Post
I haven't had a "terminal engine failure", but you'd surely want to remove the hard oil lines and trombone cooler, and thoroughly steam clean them. The engine-mounted oil cooler needs the same treatment, and some even recommend replacing it, as it's hard to totally clean out.
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
The Blue Bomber's Website
"If it ain't broke...we'll help you fix it 'til it is!"
Old 10-09-2001, 07:58 PM
