Am I missing a vacuum tube?
Good Day, this picture is from behind my throttle body. Center top of picture, is there a hose missing from the top sleeve? Or is this a normal picture?
Thanks, Dave
1984 Porsche 911 Carrera 2002 BMW R1150RT 2013 Audi A4 2020 Ford F150 4x4 |
Hi Dave, yes, there should be a cloth covered vac line to the Air valve over near the Oil tank.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Vacuum Tube
Thought this post was going to be about a 50's television set or radio.
Bob B Last edited by NICE 69 S; 03-23-2016 at 05:35 PM.. |
Thanks Dan...
no problem Dave - BTW on the Vacuum decal picture (yours may be on your engine lid), I drew in the cruise control.
It too has a similar vac line vented to ambient air - with similar or same diameter. It may be tucked near firewall, so don't get confused (bad word) with that one, as it will appear loose and available (bad phrase). :-)
I did take a good look before I posted. Will give it a go over again tommorow. I did not see anything missing from the oil tank vents. Hot coffee and a mirror I guess......thanks for the picture.
French Import
![]() My engine is out of the car and the rubber hose at the left of the valve that appears to go to the spark plug is actually loose but will connect to to the oil tank when the engine is in the car
Gilles & Kathy Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road! ![]() 86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate |
Got it! Hose was buried in the back of things. Must of pulled off during airbox removal I guess. Thanks for the pics, very helpful! "vacuum tube" ....showing my age.....
Dave
