Is the Fuel Lid Lock assembly spring available?
My fuel lid lock spring broke, is the part available? I only seem to find part number 64450430901 that is for a 356, or the door latch spring that is part 91150433100. Any suggestions? Is the 356 part compatible or close enough to make it fit?
79 SC Back to Basics! 2006 997 C2s Cabrio - Sold 1999 996 C2 - Sold |
I needed a latch and the spring assembly as well. I ended up buying a gas door lid with the latch/spring assembly from one of the pelicans here (IndyPR). I bought the 84-89 set. He has 2 sets left and 1 of them is for a 65-83. Check with him to see if he has the door and the latch/spring assembly for that one too for you.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/902163-gas-filler-doors-901-911-carrera.html Good luck. |
I ordered the 356 spring to try it out. It looks very similar in the pictures and it only costs $7.00. It is worth the try.
I have a spring and latch
lorne m.
83 SC |
It looks exactly the same, I will try to install it this afternoon and see if it fits.
It works! It feels a little less stiff , but other than that it does the job just fine!!
