Banned
Cheap rust killer
Check this out for killing rust.
http://youtu.be/TlcL_vHODkc
Old 04-04-2016, 06:35 AM
I wonder if it's better or worse in the long run as rust usually finds a way to return.
60% Vinegar, 40% water mix.
Old 04-04-2016, 06:42 AM
Banned
I think rust is alive ie there is a biological action going on
so killing rust is actually what you need to do
and any small bit of rust will regrow
Old 04-04-2016, 07:04 AM
tharbert's Avatar
There's never any really good shortcut to removing rust. If I had to clean up that panel for painting, I'd mechanically remove what I could and follow with phosphoric acid to convert any remaining iron oxide to iron phosphate. Then, use something like DuPont 5718S followed by epoxy or etch primer. There's lost of discussion about rust in the body work forum...
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-04-2016, 07:22 AM
Banned
Not saying it's a perfect solution but being a solution that's wet if small parts are submersed it'll kill rust in areas that a wire wheel can't get to. Hey think about nuts bolts and washers. Chemically phosphate dip and wash and etch primer has got to be better than not getting into areas not hit with sand paper or wire wheeled.
And since when do u buy chemicals that are non toxic and earth friendly for 1.50 a gallon or less in bulk. Any friends who own restaurants could prolly buy a 55 gallon pump top for cheap.
Old 04-04-2016, 08:21 AM
I coat my cars with used motor oil!! Cost nothing except the tarp I use. I use an Old Electric Paint sprayer. It's the only way. I remove door panels, outer panels and trunk stuff and spray everything.
I've used this practice for over 25 years and it STOPS RUST!!!
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 04-04-2016, 11:08 AM
Banned
That takes the cake. Your THE grand prize winner. I've heard EVERYTZhING now. Omg.
Old 04-04-2016, 03:46 PM
HarryD's Avatar
Molasses is another interesting method to remove rust: How to Remove Rust Using Molasses | Today's Homeowner
No end to good methods. They all have good and bad.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 04-04-2016, 05:58 PM
Banned
I coat my cars with used motor oil!! . . .
Have you developed any troubling, difficult to explain lesions on your person in that time span?!?!
Old 04-04-2016, 10:05 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Mutations acid, otherwise known as swimming pool acid. Kills rust in seconds and is dangerous to boot, kind of like juggling rattle snakes, total concentration is required, 35 years of use and never been burned, fear works! Cheap and readily available and the steel is ready for TIG welding after drying.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-04-2016, 10:34 PM
HarryD's Avatar
The disadvantage of using Muriatic Acid (hydrochloric acid) is that it eats the good metal at the same rate as the rust. Phosphoric acid (naval jelly, rust mort, ospho, etc) reacts much more slowly to bare metal than it does to rust. This allows you to avoid excessive etching of your good metal.
Harry
2020 MB E350 4Matic
Old 04-04-2016, 10:50 PM
The acid based approaches work but remove some good base metal and have environmental and safety disadvantages as mentioned. We tried the chelation approach using Evaporust and later found a cheaper version that you dilute with water. It works and saves the base metal and avoids the environmental and safety issues. I've read a molasses and water mixture has been used and works by chelation.
Sold: 1989 3.2 coupe, 112k miles
Old 04-05-2016, 07:09 AM
It works for me!! It's CHEAP and effective. I've had some ALFA's for over 25 years and I oiled them and NO RUST. I've never had to bring my cars to a Body Shop. It's a dirty job, but well worth the effort.
AlfasRule!
Old 04-05-2016, 07:16 AM
tharbert's Avatar
One not mentioned yet: Oxalic acid. You find it in tea. It's also the main ingredient in Bar Keepers Friend. It's another chelating agent: doesn't reacted with iron, only rust. It's much more potent than vinegar/acetic acid. It does great removing rusty brake dust from chrome or alloy rims. If you have a pesky black ring where you sat your beer on that nice oak trim, it will remove the ring stain. Brew a strong batch of tea and throw some rusty bits in it.
72 911T 2.4 MFI
Old 04-05-2016, 07:48 AM
Be very careful with the used oil spray: the contaminants contained in that used oil are carcinogenic. It's done a lot here in NW PA. The guy up the road did it as a business and I would cringe to see him applying it with a spray gun without a mask. He died of lung cancer a few years ago. Not saying it's not useful; just protect yourself with a good cartridge-bearing mask.
Makes a heck of a mess underneath the car and is miserable to work on afterwards. Didn't seem to help much with the Jeeps I've owned over the years, although they may have gone to hell a little earlier without it. My solution: stick with Volvo or BMW which seems to have a higher quality steel and is better winterized. Not a bit of rust on my '88 Volvo!
I like to use Fluid Film instead: comes in spray cans & gallon cans. Is lanolin based & is safe & clean to use. Check it out as a transition away from used motor oil please.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-05-2016, 07:54 AM
When I cleaned up the floor of my '70 VW bug, I used a wire wheel first, then sprayed it down with phosphoric acid. They sell it by the gallon at Home Depot. After it did it's job, I cleaned the residue with denatured alcohol. Applied silver primer & 2 coats of POR15 to finish the job.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 04-05-2016, 07:58 AM
Charles Freeborn's Avatar
Vinegar is simply an acid. Next step up in strength is Muriatic acid - get it at home depot - it's used for masonry cleaning. When cars are "dipped" to remove rust it's an industrial version. You'll want to neutralize afterwards (baking soda).
Best spray on rust preventer is LPS 3
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 04-05-2016, 08:14 AM
Came up in the ALFAbb today!!
https://www.ncptt.nps.gov/blog/comparative-study-of-commercially-available-rust-converters/
AlfasRule!
Old 04-05-2016, 08:25 AM
TheSt|G's Avatar
These cars are pretty good at coating themselves with used motor oil.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 04-05-2016, 12:21 PM
