Really dumb pulley question
Hi guys
Just replacing the alternator pulley on my 82 sc. The previous pulley disintegrated....
So I sourced an identical pulley, got the fan boss welded (as advised in here) and have reinstalled;
So Im now wondering if the pulley arrangement is wrong, and maybe thats why it failed in the first place, but cant really work out how it should go together. The car originally had an air pump, but this has been removed. Im thinking that maybe I should get the
single pulley...
I cant see in theory why a double pulley with one belt should be a problem...
Anyway, I would welcome any comments on the arrangement in place
Cheers
Kevin...
Old 04-29-2016, 05:20 AM
theiceman's Avatar
I have a 78 sc and have had a double pulley for eons , absolutely no issue . I considered going to the single for looks only but never bothered.
I didn't think the 82s had an air pump. I thought they had gone to the lambda sensor by then and did away with it , you learn something every day
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 04-29-2016, 05:24 AM
GaryR's Avatar
Send a message via ICQ to GaryR
It's hard to get the pulley alignment wrong if the fan housing is seated correctly, while there is absolutely no issue using the two belt pulley I would put a single in for aesthetics (and it weighs less too!)
Gary R.
Old 04-29-2016, 05:27 AM
Air Cooled
Craig_D's Avatar
I've got a '78 running the double pulley with the single belt and haven't had any issues.
I, unfortunately, have to re-install the air pump every single year to pass emissions (which sucks given that the air pump isn't really connected, it just looks like it is, and I pass).
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 04-29-2016, 08:28 AM
Im still confused about this bloody pulley, and its driving me dememneted...������
Does the 'double pulley' consist of the standard half pulley AND the larger pulley that was fitted to my car i.e. are two pulleys (or half pulleys) fitted. My car was fitted with one part - which I think should have been fitted with a second half pulley. But I cant find any diagram/photo/ thread that supports this.....!
Old 04-30-2016, 10:38 AM
76 911S Targa
Yes. The inner half pulley mates with the half pulley which is the fan hub. The shims determine the distance between the halves and thus the tension on the belt. The air pump pulley is outside that half pulley and drives the air pump belt. There is not a separate fan belt pulley, just the two halves described. If you have AC drive belt then there would be another pulley as part of that system.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 04-30-2016, 10:45 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
single pulley...
Cheers
Kevin...
In the above picture, it looks like you are using the smog pump groove on the fan pulley as the drive grove for the fan (from the crankshaft), and if so, that is incorrect. The actual fan pulley groove (talking about the groove that is "made" by the fan hub itself and the outer pulley half) is what the crankshaft pulley & belt should be connected to.
Old 04-30-2016, 10:52 AM
Ok, that makes sense, but surely the widest groove possible is the width of 6 shilms - is that enough?
Giess I will have to have a play with he car tomorrow and see if it works!
Thanks guys, much appreciated...
Old 04-30-2016, 11:07 AM
