1979 930 @outlaw3.4
MZ3 SBC's Avatar
Help with oil level gauge
https://m.youtube.com/watch?v=29pnrG_v6wM
As you can see in the video my oil level is pegged. After searching the threads - I bought a new sending unit...
Well it's not the sending unit. I even reversed the wires thinking they could have been reversed.
What else can it be? The gauge pins on max as soon as I turn the key.
Old 05-17-2016, 07:29 PM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
http://rennlist.com/forums/911-forum/686198-oil-level-gauge-pegged-now-fixed-2.htm
Old 05-17-2016, 07:50 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check to make sure the ground on the Sending unit is connected and also check behind the gauge to insure the contacts are clean and solid.
'85 Carrera Targa
PCA/POC
Old 05-17-2016, 08:39 PM
bavaria911's Avatar
I did what Darco recommended, but it was still reading max once key was turned on...even before the engine was running.
The solution was to replace the oil sending unit inside the oil tank. Found a good used one here on PP and the gauge now reads properly.
Scott
Bavaria911
1970 911T w/ 2.4S
1971 911T Targa w/ 2.2
RG Member # 818
Old 05-18-2016, 04:31 AM
Charles Freeborn's Avatar
Sending unit for me too. Check all the wiring and grounds first, and if no go change the sender.
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 05-18-2016, 07:47 AM
DRACO A5OG's Avatar
If you do need to change out the OLSU, here is my tutorial.
http://forums.pelicanparts.com/porsche-911-technical-forum/594192-oil-level-sending-unit-how-service-repair-maintain.html
'85 Carrera Targa
PCA/POC
Old 05-18-2016, 07:52 AM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
How does the sending unit work?
Maybe that will help me understand how to diagnose issue ...both wires seem to have no power . Should one be powered?
Old 05-18-2016, 06:25 PM
DRACO A5OG's Avatar
Only when car is in the ON position and properly grounded.
Pegged up mean no ground.
'85 Carrera Targa
PCA/POC
Old 05-18-2016, 06:29 PM
1979 930 @outlaw3.4
MZ3 SBC's Avatar
Good news - not the gauge!
I changed the sending unit - still no good. I checked ground - ground good. I checked positive line - no continuity.
I ran a direct wire around car as suggested and gauge works.
So somewhere between the gauge and oil tank there is a break in the line...
Old 05-19-2016, 12:36 PM
