Bent bell crank?
Would you mind telling me if the bell crank (left side) from the throttle linkage in the engine bay is supposed to be bent or not. It goes into a '79 SC. Thanks!
Member 911 Anonymous
Should not be Bent
Here you go: http://forums.pelicanparts.com/porsche-911-technical-forum/609976-fix-binding-accelerator-not-pedal-bell-housing-bushings-not-even-tunnel.html
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC Last edited by DRACO A5OG; 04-24-2015 at 07:22 PM.. Reason: sorry, re-red your thread :-( |
Hey Draco, I checked out your thread, but I didn't see any information about the crank itself. I just replaced the bushings (plastic). Do you see how the crank on the left is bent to the left a bit? I don't know if this is factory or not.
Post #3 I am showing the Bell Housing side of the arm:
![]() Just straighten her out. But it will require you to make some fine adjustments on the linkage to put back to OEM specs.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Oh I see. Thank you. So, it's supposed to be straight. Do you have any idea what has caused it to bend?
Not sure, maybe PO or wrench did it by accident???
Perhaps. I'd hate to think that someone would be so negligent.
Just make sure it does not bind anywhere.
New-ish 911SC Targa Owner
Mine is also bent...
Someone must be running around bending them after dark. Can i get the part numbers for the bushings that go with this rod thingie? Mine are long gone and i can't seem to navigate the pelican parts lookup well enough to be sure I've found the right part.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Mine gets bent every time I drop the engine, because that ball cup connection on mine is particularly tight. Just bend it back straight. Don't overbend it, it will bind if you get it kinked inwards. Straight or outwards slightly is just fine.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Bushing
901 423 253 00, 2 each Bruce |
Mine was bent too and catching on the engine tin. I just straightened it.
Thanks Bruce!
Banned
when fitting carbs to achieve full throttle linkage at times has to be manipulated.... if you are running carbs and it throttles well leave it where it is...
