exhaust studs rant
I was bitten by the exhaust stud virus yesterday. I had to change an oil hose out and one of the headers had to come out. Five nuts came out with the studs attached to them. One, a barrel nut, was so deep onto the stud that there was not enough room for the hex bit to bite so it stripped. The barrel nut had to be drilled out, then the stud had to be drilled out. What a pain. !!! I won, but the battle was hard fought.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-26-2016, 06:14 AM
Discseven's Avatar
Heat works wonders on those nuts.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-28-2016, 03:35 AM
When they round out, as long as you can get at it, heat red hot and use an air hammer bit on the side of the nut to start it turning and work it from there.
206 637 4071
Old 05-28-2016, 06:19 AM
rent a set of acetylene tanks and get a set of hose/gauge/mixer/tip at harbor freight and keep it just for these situations. Oxy/Acetylene is great for heating up these old bolts.
Another approach is one of these:
http://www.amazon.com/Bolt-Buster-BB2-ACC-Handheld-Induction/dp/B00ATSL7VE
A friend uses one instead of torches whenever possible - truly magical and can be used for a variety of things that need heating from wheel hubs when changing bearings, to expanding pipes when sleeve fitting joints, to nuts that are seized, and so forth
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 05-28-2016, 08:36 AM
Aren't there copper nuts for that application?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-28-2016, 10:03 AM
