Tell the HOA to repaint those stripes. That is real tacky.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Oil leak location.
If not, let's do a little "fault location". It could be as simple as the "triangle of death", or a valve cover gasket. Clean up the engine with some Simple Green , then have a look. At least the building manager will know you are making an effort. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." Last edited by 86 911 Targa; 06-17-2016 at 10:15 AM.. |
Admire you guys. Would respond to you individually but believe consolidated response will work better. And... excellent input from you... much appreciated--TY!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Sounds like the Roney Palace condo association!
Gary R. |
Short of a cat litter box with cat litter that gets placed under the car.....hey, the cat has to "go" somewhere and space in the condo is tight, don't you know.....in the middle of the night use a jack hammer and remove a 3'X3' section of the slab down to the dirt and THEN place a litter box with oil dry in it. Problem (technically and legally) solved.
Oil.
Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
"Cannot leak any fluids"......c'mon now. You are in Miami? Those with vehicles that are equipped with A/C and are dripping water from the evaporator drain tubes---like they are designed to do---aren't in violation? Isn't water in this respect a "fluid"?
sounds like management is in bed with the trades. someone's being paid off for those idiotic maintenance repair contracts. pretty common when there is no transparency.
GOM (Grumpy Old Man)
Having lived in a condo and also been a member of the board, the first piece of advice is to read your HOA rules carefully and closely. That is your contract to the HOA as a member. If there are not stipulations about 1) leaving oil on the floor of your assigned spot and 2) using some device to catch any leaks, do what the f*&k you want. The only recourse the HOA has is to fine you, but only if it is allowed under HOA rules. They can fine you all they want but the board likely won't have the balls to follow through with a lawsuit, which would what it would take to enforce the fines. If you have legal standing based on the HOA regulations, there is nothing the board or manger-for-hire can do about it.
HOA boards are typically run by power-hungry dumbasses with nothing better to do. I joined my board because I got sick of them making stupid decisions and wanted some visibility into what the hell was going on in their meetings. I was threatened a couple times for fines but they didn't know they were dealing with someone that could read and was going to push back. If it isn't in the rules, you aren't violating anything. That said, it doesn't stop them from adding amending the rules to prohibit all the BS you are being threatened with. Good luck.
Instagram: @3pedalposse |
OK legal types, how about this:
1) Medium size shallow pan on the garage floor, holding water 2) Smaller size pan that is placed in the medium size pan that floats 3) Smaller sized pan collects oil from above Does that not meet all the criteria? ![]() Or better yet: Run a craigslist ad in help wanted soliciting dirty diposable diapers to be placed under your car nightly for 50 cents a day. Collect the 2 quarters from the rear bumper. Thanks. Last edited by SCadaddle; 06-17-2016 at 12:58 PM.. |
how about a car cover that touches the ground so they can't see under? They would have to pull it up to look. Hide a drip tray under there.
How about one of those cookie sheets with a little depth and fill it with cat litter.
1982 911 Targa, 3.0L ROW with Webers |
To me, there's nothing more frustrating than an unreasonable person. Sincerely, I hope you find a way to resolve it. I was thinking of some kind of fire-proof absorbent material to collect the oil at the location of the drip but nothing really comes to mind. Perhaps this will stir an idea.
Best of luck. |
Still here
Just sayin' Last edited by pmax; 06-17-2016 at 01:01 PM.. |
No, but quite possibly an '80 model silver targa w/85 3.2 if you read the fine print at the bottom of the first post.
Know what? A small catch pan with four hooks that attach to the oil return tubes may be what you need to build.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Go to home depot..get a couple spring loaded clamps, zip tie them to a shallow baking pan (foil ..like at the grocery store) and stick a puppy Pee Pad in there each night. Clamp it to the bottom of your licence plate. Done.
Take it from me..I was on Monster Garage! Ha ha
CARS ARE FUN! |
Guys... Nothing can go on parking surface (except car) per HOA rules.
Neglected to respond... yes, this is daily driver. Gerry... Tony... here's MacGyver'ing reference. Look at photo in my first post and you will see Valdez slick is different than seen below. This is because since the first pic was taken I've cleaned the floor. Images below were just taken. Car was driven yesterday... sat over night... and was not driven yet today so relationship of car to slick is accurate. Drip location is obvious. Exactly where leaking originates... of no concern---because I'll get to a rebuild soon. For those that have to know... chain housing is sealed with flexi-seal so that's not it. Look carefully at seam and you'll see extrusion of seal. More likely it's chain housing to head, cam oil feed line, oil sending unit... or combo. ![]() Put camera directly over slick and shot straight up. ![]() '85 3.2. Stock. (This is not pic from today---so leaking oil is not seen here. Am showing for engine component reference.) I have some ideas but rather than stick my nose in this... since you've taken the initiative to solve this puzzle Tony, I believe you should have ownership/authority of solution without my interference. Of course if you want my input... I'm at your service. And no worries if indeed you prefer my yap shut on this ![]()
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. Last edited by Discseven; 06-17-2016 at 02:15 PM.. |
just drag hitler to every audi over 5 years old in the parking lot and point under it .
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Great input here...but... put yourself in my position for a moment. Am in and out of garage sometimes multiple times per day. Would you want to be laying on garage floor two times with each trip! Solution should be Da Vinci'esque---simple...brilliant. Should be able to lean over and put barrier in... 5 seconds max. 3 secs to remove.
